Looks as if there are no cams at all
I think so too...if you watch the pictures of the BMW engine in this topic viewtopic.php?t=2017manchild wrote:I agree but compared to same parts on engines of Renault, Toyota, BMW and Mercedes it looks different.
I agree completely. Although, I guess it does make it easier for an independent team to develop an engine. I get so torn about the regulations. I'm glad I'm not the one making them.Up until now the teams have shrunkwrapped the castings around the internals real tight. That way you can see how the heads and cams are positioned. In this sense the rule is negative thing for us techies.
Technically, you're right. The area above the transmission usually houses hydraulics and sensors, with the pushrods mounted on top; this is often a carbon fiber housing bolted to the transmission casing to form a single rigid member. This assembly then bolts to the engine via studs/bolts on the cam cover and below the rear main seal. Arranging it that way maximizes the distance of the mounting points, thus contributing to greater rigidity in both torsion and bending. There could also be some axial loads generated through the damper's mounting points.Since when are gearbox mounting points on top of the valvetrain/cams cover?
Since the dimensions of the engine, particularly the height of the head, are so limited that you can’t further move the gearbox mounting points without suffering bending and torsional issues. That was more than 10 years ago.manchild wrote: Since when are gearbox mounting points on top of the valvetrain/cams cover?
Renault's gearbox is not attached on valve cover but on cylinder heads (at least it was like that on R24/R25). Also, rods are not connected to gearbox but to engine.Reca wrote:Since the dimensions of the engine, particularly the height of the head, are so limited that you can’t further move the gearbox mounting points without suffering bending and torsional issues. That was more than 10 years ago.manchild wrote: Since when are gearbox mounting points on top of the valvetrain/cams cover?
To be honest, I see nothing strange with that Honda engine, to have the mounting points on the valve cover is pretty standard, then since the head is very low it needs protuberances to put mounting points on favourable position on both sides, for chassis and gearbox.
In Renault case (and on the RB2) there are two rods running from the rear edge of the tub to the gearbox, at the sides of the airbox, since a few years now. You could say that engine is a semi-stressed member in that case. Anyway the mounting points for gearbox are visible on the valve cover of the RS25.
