Sorry Rieker,
I don´t know the answer to your question, and I don´t want to give you a wrong information.
The obvious answer would be, the one which is closed to an F1 rear wing, but as I don´t know if there wing is based on any NACA profil, it´s a bit difficult to guess.
I don´t think that the flap profile as such will have a too great effect.
I think it`s more important to get the relationship between Flap and Mainplane right, and be as close as you can manage to the flow/load conditions of the whole assembly. If you see it as a "unit" (main pofile + flap) it may does not have much to do with a "wing" in the classical sense.
It´s pretty high camber and highly loaded, therefore very draggy.
If you look, the flap has allmost a 90° inclination to the main plane (it maybe is 75°) but nowhere near of a "normal wing"
Sorry, that I can´t help you with this one, but I´m sure there are others on here which maybe able to venture an educated guess.
