Hi guys,
We are busy working on building the world's first 1991 F1 simulation software. (the reason for choosing that year is that it was the last year that F1 cars were using predominantly manual gearboxes and passive suspension).
I'm a part of the team doing the research.
We are stuck on the types of gearbox used (synchromesh, dog, half-dog, spur, helical).
The only visual driving information we have are these 2 footwell video's from Katayama driving a manual Tyrell 021 in '93
One slow lap where he uses the clutch almost everywhere:
http://www.youtube.com/watch?v=MgB4a2eN ... e=related
and one insane qualifying run where he sporadically uses it, predominantly on upshifts(?), and once on downshift entering spoon.
http://www.youtube.com/watch?v=pf7ogFFJ ... e=related
His feet are tapdancing away on those pedals like there is no tomorrow.
You see in building an accurate gearbox for the simulator we can alter values such as:
-If you clutch past x% the gear will always engage (not sure if that is correct but that is the current mode).
-If you do NOT clutch past x% then the gear will only engage if the difference in speeds of gears is less than y%.
These two effects are computed independently, x is customisable generally or by car, y is customisable generally or by car and can be different for upshifts or downshifts.
Is there anyone here who has driven a manual F1 car in anger or knows about its gearbox operation who might be able to answer the practical questions below?
What would practically happen / what would you experience in the examples below for a circa 1991 manual F1 car. I understand that it is unlikely that there is someone knowledgeable enough to answer them all, so even if you know a tiny snippet of info on a particular question if would help us tremendously.
Upshifting
1. a. (Fast Clutch) If you just do a normal upshift, dip the clutch very fast while lifting the throttle it will just shift up I presume. Can anything go wrong with an upshift if you use the clutch like this?
1. b. (Fast No Clutch) What about when you do a fast upshift not using the clutch? If you just quickly lift slightly / or fully off the gas and engage the higher gear. What could go wrong, or will it be 95% foolproof? Does it depend how much you lift off the gas?
1. c. (Slow Clutch) What would happen practically if you upshift like in a roadcar. Lift off the throttle slowly, press the clutch slowly, (revs drop), engage the higher gear. Let clutch out slowly.
1. d. (Slow No Clutch) What if you do this upshift (again) slowly without using the clutch but by trying to match rpm's while in neutral (like you can in a family car)? I.e. hold stable medium rpm so you can ease into neutral, then hold slighly lower rpm until the sweetspot so it gently slots into the higher gear.
Downshifting
2. a. (Fast Clutch blip) If you just do a normal fast downshift, press the clutch fully very fast while braking, heel and toe so you hear the engine (to an unspecified rpm), engage the lower gear and release the clutch. Can anything go wrong with a downshift if you use the clutch like this?
2. b. (Fast Clutch no blip) What would happen in the above example if you did not blip the throttle, but tried to engage the lower gear and released the clutch pedal quickly without the "heel"
2. c. (Fast No Clutch blip) What about when you fast downshift without using the clutch (like in the Katayama video)? If you just do a fast clutchless downshift, while braking, heel and toe so you hear the engine (to an unspecified rpm) and engage the lower gear. Can anything go wrong with a downshift like this? Does the "heel" rpm rise matter in terms of rpm?
2. d. (Fast No Clutch No blip) What would happen in the above example if you did not blip the throttle, but tried to engage the lower gear quickly without using the clutch and without blipping. Ok this is probably the stupidest one. What would happen is probably the same as in your family car.
2. e. (Slow Clutch blip) What would happen practically if you downshift like in a roadcar. Lift off slowly, press the clutch slowly, (revs drop), heel to increase rpm, engage the lower gear. Let clutch out slowly?
2. f. (Slow Clutch no blip) What would happen practically if you downshift like in a roadcar. Lift off slowly, press the clutch slowly, (revs drop), no heel to raise rpm, engage the lower gear. Let clutch out slowly?
2. g. (Slow No Clutch blip) What if you do a downshift slowly without using the clutch but by trying to match rpm's while in neutral (like you can in a family car)? I.e. hold stable medium rpm so you can ease into neutral, then hold slighly higher rpm stable until the sweetspot so it gently slots into the lower gear.
2. h. (Slow No Clutch no blip) Ok this one is again stupid.
Thanks again for reading all that guys! If there is any place on the internet that has info on this it is here.
