xpensive wrote:I still believe that MGP, just like many other teams, were bit hasty jumping on the pull-rod suspension bandwagon. When looking at the layout and geometry, with its three-dimensional pull-rod movement and short spring compression, it suggests to me that it might be very easy to get this wrong.
Combined with the added complications for adjustments and basically no opportunity for testing during the season outside of the races, it must be a challenge to implement the pull-rod unless you know xactly what you are doing?
Yes, You alright X, if that is what explain Brawn on AMuS, when somebody asked him about the W02 concepts. He said, it's the development state where they got problems, because last year when they start developing this car, the team was not in the best shape in the technical point of view. That's the reason, why they are getting wrong on the rear suspension, on the cooling, and what they are solved now: on the DRS.
But as Brawn also said, if you found your weaknesses, you got the weapon in your hand to make it different. I think that is what Mercedes doing now, but it needs time, to solve all the problems.
I'm very happy with this Canadian result. When it rains, this track hide the big differences between the cars, that is the way Schumacher can show his true abilities. In the red flag period, they did a nice work on the setup of the car, so it is shining in the rain, but then 2 second of the pace, when it's dried up. But he is still posting nice, consistent lap times, despite the wet weather setup.
The only problem for me about this race is, that we don't know, if they can sort out their rear tire issues, as Brawn give a promise, they are trying to solve it. It was the right track to compare it to Monaco, but the rain washed it. At least on Friday, they are consistent (as usual).
Anyway, FIA now give the big thanks to the off-throttle gases from Britain. I think it's a great place to do that, as we can see, how much it ruins the top teams.
What do you think guys? Is it good for our lovely team?
