Mercedes GP W02
mantikos
mantikos
35
Re: Mercedes GP W02
n smikle wrote:
mantikos wrote:
luca wrote:Image
They added a guide vane. That wasn't there in the initial picture posted a couple of pages ago.
You are right, the added the outter guide vane...the metallic unpainted one...although I am still curious about the bell shaped taper toward the exhaust exit and the fact the pipe is much higher than others who have outter blown diffusers and is not aimed downwards towards the underside of the diffuser at all...this is very unique in addition to the shorter length and the fact that the exhausts are more outboard vs the others...
Supersonic Nozzle. To make the air leave at one constant speed over a wide range of flows.
Aah it's a con-di nozzle, that makes sense! that helps in maximizing the benefit from the kinetic energy fo the hot gases!
http://en.wikipedia.org/wiki/Convergent ... ent_nozzle
mantikos
mantikos
35
Re: Mercedes GP W02
Another shot of the lower/rake T-tray
http://www.flickr.com/photos/f1photos/5 ... 147404978/
mantikos
mantikos
35
Re: Mercedes GP W02
verticle angle of the exhaust not xlearly visible from other shots... (contrary to initial impression it is pointed downwards)
http://www.flickr.com/photos/f1photos/5 ... otostream/
luca
luca
Re: Mercedes GP W02
mantikos wrote:http://www.flickr.com/photos/f1photos/5 ... 147404978/
MS didn't have that sensor, he instead has a different looking sensor
I also notice the T-tray in both pictures is now much lower to the ground in the front than in the rear...aka rake
Just out of curiosity, how are those sensors "attached" to the engine cover?
mantikos wrote:verticle angle of the exhaust not xlearly visible from other shots... (contrary to initial impression it is pointed downwards)
Good catch! :)
mantikos
mantikos
35
Re: Mercedes GP W02
mantikos
mantikos
35
Re: Mercedes GP W02
Good catch! :)
Not a clue!
Thanks bud!
luca
luca
Re: Mercedes GP W02
Red Bull's, Ferrari's and McLaren's rakes still seem to be a bit higher than Mercedes's.
mantikos
mantikos
35
Re: Mercedes GP W02
luca wrote:Red Bull's, Ferrari's and McLaren's rakes still seem to be a bit higher than Mercedes's.
Well I think the front of the T-tray on the Merc is lower than on the MaLaren
siskue2005
70
Re: Mercedes GP W02
I wouldnot go on and look for Rake angles on car which has wet weather tyres
Coz these rain tyres increase the ride height of the car on itself, especially the rear height
DM0407
DM0407
Re: Mercedes GP W02
It think the rake would be more easily determined when compared to the rear wheel seeing at the front of the car and the T tray would be sitting at about the minimal allowable height... Unfortunately those pictures only show the rear of the RB which does seem to still have an extreme rake compared to the others.
DM0407
DM0407
Re: Mercedes GP W02
siskue2005 wrote:I wouldnot go on and look for Rake angles on car which has wet weather tyres
I see what your saying but the angle of attack should still be relative regardless of what tires you have on.
mantikos
mantikos
35
Re: Mercedes GP W02
Same tires for everyone, so although there would be a small increase in the overall height both in the front and rear, it would be the same for all the teams
mantikos
mantikos
35
Re: Mercedes GP W02
Agreed!
240
Re: Mercedes GP W02
horse wrote:
zgred wrote:Image
Ferraripilot wrote:so a new type of diffuser gurney tab. should have known!
Yeah, it's an interesting idea this. Sort of bringing the Gurney around the corner to meet the channels turning outwards between the rear wheel and the diffuser, presumably improving performance out towards the back of the rear wheels. They're pretty big, tho, ay? Perhaps they act a little like a fence, as well, to help encourage more exhaust gases under the car?
This just a cheap and slap dash technique to get cheap and dirty down force.
It's a damn basically. The exhaust will flood into that little pocket and up the static pressure on the back of that diffuser.
It's a pretty smart but barbaric idea.
It's brain surgery with a sledge hammer.
The drag will increase a lot. They are taking advantage of their straight line speed.
bill shoe
bill shoe
151
Re: Mercedes GP W02
ringo wrote:Image
Or it creates higher drag (blockage) on top of the floor which forces more exhaust flow along the underside of the floor where it's most useful.
