Mercedes GP W02
Re: Mercedes GP W02
JohnsonsEvilTwin wrote:
Byronrhys wrote:
JohnsonsEvilTwin wrote:I have only seen the usual wing... :(
Both guys ran it, Msc is testing it right now also.
Internet back!
I noticed a large amount of Flex just before he went off!
Yeah. That is what I noticed as well. Flexing so much towards the sides of the wing.
Dragonfly
Dragonfly
Re: Mercedes GP W02
That would explain the rear tyres locking and loss of control then.
Spa 2012
JohnsonsEvilTwin
Re: Mercedes GP W02
Dragonfly wrote:That would explain the rear tyres locking and loss of control then.
Can you expand a bit on that Dragonfly?
More could have been done.
David Purley
madly
madly
Re: Mercedes GP W02
NewtonMeter
NewtonMeter
Re: Mercedes GP W02
I think he's implying the car has a disproportionate amount of front down force. The high front down force causes the front wing to flex more severely. However with too much frontal down force the rears might become relatively unloaded - especially under braking. Similar to the way the rear tyres of a car might become unloaded leading to lift-off over steer. Therefore with a much smaller force on the rears than on the fronts, it's easier to lock them causing over steer.
At least, that's what I read into his post.
Ok, reading that it sounds confusing. In brief, the wing flex is a sign of very high front downforce. This causes the front tyres to stick to the track much more compared to the rears which leads to oversteer....
Nothing is foolproof to a sufficiently talented fool...
Dragonfly
Dragonfly
Re: Mercedes GP W02
No.
@NewtonMeter
Thank you for explaining that to JET, although I think he knew this beforehand, but just tried a bite on me.
Whole thread long it is constantly being said that the MkIII FW produces more DF which shifts the balance of the car, making the end grip even weaker. That's all.
Spa 2012
LegendaryM
Re: Mercedes GP W02
MRVC: Tolo Racing
ForMuLaOne
ForMuLaOne
Re: Mercedes GP W02
Heheh.....well, at least they are good in copying....this thing flexes more than RB`s wing...
Re: Mercedes GP W02
Is that how the front wing flexing really should look like? It looks as if it were gonna come off!
Byronrhys
Re: Mercedes GP W02
The vanes on the endplate finally arrive, the inner most blades of the diffuser and how the are formed are pretty interesting.
Mandrake
Mandrake
Re: Mercedes GP W02
Finally some "dramatic" changes at MGP :D MK III wing, New RW Endplates, new exhaust (as in Silverstone) let's see how much they'll keep for qualifying on the car
dren
227
Re: Mercedes GP W02
How did MS's car handle? I read on another forum it looked bad.
Honda!
JohnsonsEvilTwin
Re: Mercedes GP W02
He pushed and nearly came off on the bit kurve, had a bit off a tank slap moment which was really well held.
I think by that and the off he ha at Dunlop kehre, says to me he may be on a higher fuel load. I could be wrong...
David Purley
JohnsonsEvilTwin
Re: Mercedes GP W02
David Purley
JohnsonsEvilTwin
Re: Mercedes GP W02
Just watching some onboard FP2 footage and yes, Nico has the MK3 wing.
It flexes visibly more than anything out there too. Still havent seen the times....
David Purley
