ringo, I am not misunderstanding nor putting things in others' mouths; neither I am changing my point of view, which has been the same throughout this forum.
Nobody is paying the devil's advocate here: if it seems so to you, it's because you are refusing to discuss, and just reject what others say.
Allison says that the fee is used to enhance the vortex on the leading edge of the floor: that's the vortex that comes from the barge board. If the exhaust interact with this strong vortex, then it probably twists with it, and does not shot wide.
If in your geometry the bargeboard does not produce such a vortex , it would be impossible tpo see such an effect even of the simulation was performed with adequate methods and resources.
