No?
Hey. Flat floors and stuff. Super wide tyres. Thats techincal
Was the narrower track not brought in to control speeds? Unless I'm mistaken, that would likely be why the cars haven't been returned to that width already, and in turn why I doubt they will any time soon, sadly.mep wrote:Aaaah nice picture.
I agree the width of the cars should be increased it makes the look more apealing and it can also influence overtaking in a positive way.
The drag of the cars will be increased and therefore the effect of slipstream. Something FIA now tries to create artificially with their DRS.
If it was introduced to reduce speed then only cornering speeds because you have a slightly higher amount of load transfer. The groved tires where introduced to reduce grip and by this cornering speed. The reason for the reduced width was as far as I remember to make overtaking more easier because 2 cars driving side by side will demand 0,4m less space.Tufty wrote:Was the narrower track not brought in to control speeds? Unless I'm mistaken, that would likely be why the cars haven't been returned to that width already, and in turn why I doubt they will any time soon, sadly.mep wrote:Aaaah nice picture.
Ah, thanks. So, in theory, reverting to 1990-style regs would solve that problem?mep wrote:If it was introduced to reduce speed then only cornering speeds because you have a slightly higher amount of load transfer. The groved tires where introduced to reduce grip and by this cornering speed. The reason for the reduced width was as far as I remember to make overtaking more easier because 2 cars driving side by side will demand 0,4m less space.Tufty wrote:Was the narrower track not brought in to control speeds? Unless I'm mistaken, that would likely be why the cars haven't been returned to that width already, and in turn why I doubt they will any time soon, sadly.mep wrote:Aaaah nice picture.
Well this is true but a very primitive logic.
Overtaking must be based on a drag advantage therefore you need cars which have high drag in general and a lot of slipstream. Took the FIA many years to realize that and they have still not found a natural way to solve it.
Agree. I like how the engine cover curves down to the sidepods instead of tailing off in the current FIA-required engine-cover triangle shape that gives more space for sponsors.timd wrote:Just saw this pic on another F1 site and just thought. God damn isnt that what all F1 ass should look like
