New overtaking rules from FIA
lebesset
lebesset
if you move off the racing line to defend , you can't move back
not enough , but a start !
http://www.f1fanatic.co.uk/2011/12/07/f ... ules-2012/
to the optimist a glass is half full ; to the pessimist a glass is half empty ; to the F1 engineer the glass is twice as big as it needs to be
Holm86
254
Re: new overtaking rules from FIA
I think its to much. What is the next gonna be?? "The car in front must slow down and hold to the opposite side of the track whenever a car is approaching from behind" ??
Richard
Richard
It should be called the "Schumacher Monza" rule. How times have changed, he was once untouchable but now they create special rules to keep him in his place.
dren
228
Yeah, not being able to move back will make it worse to watch. Might as well move over and let the cars pass.
Honda!
beelsebob
beelsebob
85
richard_leeds wrote:It should be called the "Schumacher Monza" rule. How times have changed, he was once untouchable but now they create special rules to keep him in his place.
Not forgetting canada too.
I think it's fine as long as everyone plays by the same rules. This just means that you have to consider not just your own line but the line of the driver chasing. It makes you be more strategic as opposed to just laying down a block. Besides, now that it's a rule, there's no more ambiguity about what driver can or can't do to defend his position.
strad
117
Ridiculous and will make a bore fest
Sir Stirling Moss
WhiteBlue
92
It will make it easier for the stewards of the meeting. This rule was always there as a non written rule. It is good that it is now set into words and written down. Drivers are still allowed to defend but they may leave the racing line only once between corners and may not come back on the line before they reach the apex of the next corner. I approve the rule change. There should be fewer accidents due to this rule.
N12ck
Since when was this a rule? In karting you can defend by moving across off your line once, then returning to your normal line, if you dont return to your normal line, you get a worse exit out of the corner meaning an overtake is undefendable, this rule shouldnt be added in IMO
Budding F1 Engineer
Goran2812
Goran2812
27
well... have a deeper entry line, make the other car brake harder and that's it... :P
Visit my photo page! -> http://www.gorankphoto.com/formula1
hollus
Has anyone seen the exact wording of the rule? I am a bit worried about where exactly does this "racing line" lay.
TANSTAAFL
N12ck
Goran2812 wrote:well... have a deeper entry line, make the other car brake harder and that's it... :P
Its not that simple though, cos the guy defending will end up loosing speed out of the corner (I race karts) and having to basically give up the place on the next straight/ corner, which is ridiculous, so basically kiss goodbye to battles, and kiss goodbye to quality defending, this is another gimmic which will allow the following person to breeze past very quickly, not what racing is about... The art of racing is slowly being destroyed
Budding F1 Engineer
Billzilla
Billzilla
lebesset wrote:if you move off the racing line to defend , you can't move back
Without reading that link, that's the similar to what we do in Australia and it works well.
You're only allowed one blocking move, no more, between corners.
scuderiafan
Terrible rule. I understand not letting the drivers go back and forth and defend freely, that could cause a bad accident. Essentially telling drivers to play dead though? I doubt it will make a difference anyways. If a Driver A stays in the middle of the track and doesn't move, Driver B will either have to smash into him on the inside of the corner, or run wide into the grass going on the outside.
"You're so angry that you throw your gloves down, and the worst part is; you have to pick them up again." - Steve Matchett
Patiently waiting...
240
The rule is not terrible.
In fact it doesn't even sound like it's new. It's basically a clarification on what was already implied by the previous rules.
I was saying this all the time, and i was thought to be a fan boy for making up stuff to suit a specific driver.
Now drivers have think more when they defend. Now they have to make their car wide by choosing a single line.
That is what true defending is about. Check Hamilton defending Vettel in Germany.
Or defending Webber in Korea.
Shumacher's moves are cheap and require no real skill to pull off.
Defending is not over guys, it just got a little bit more harder.
But fret not. I don't think overtaking is going to be much easier with this rule.
The attacker still has to get pass and be in a position to enter and exit the upcoming turn faster than the defender.
In fact i don't think it will change the racing much. Remember most passess nowadays are with big speed differentials, meaning they happen on the straights long before the braking zone. It is only in a case like shumacher/hamilton where overtaking is being attempted in the braking zone.
