CaterhamF1 CT-01 Renault
aleks_ader
90
Re: CaterhamF1 CT-01 Renault
It is that porpouse of this vent (yellow cloud) to make a vortices around this curved shape on top side of drivers shoulders guard (red arrow)?
Maybe it helps to reduce drag from beam wing?
shelly
shelly
136
IIRC it is typical. A lot fo car had it in 2011 (and 2010 before) to help cooling as it exploits a loophole in the rules for placing air outlets within a certain width
twitter: @armchair_aero
Lurk
beelsebob wrote:Now that we can see the rear of the car more clearly, it becomes obvious that what looks like the pull rod is something very interesting there – it travels in front of the front part of the lower wishbone. What's going on there?
The drive shaft is now much clearer as travelling just above the lower wish bone in a position that would be obscured by the beam wing from the rear shot.
Same as RB7 (which is normal since it is the same rear suspension & gearbox)
Caterhamrules
Caterhamrules
Mchamilton
Mchamilton
[quote="tok-tokkie"][quote="Isak"]High res versions. Right click -> show image to get them in fullsize.
something different going on with the leading edge of the floor below the sidepod barge boards?
beelsebob
beelsebob
85
Mchamilton wrote:something different going on with the leading edge of the floor below the sidepod barge boards?
Good spot! I wonder if that's designed to push air under the edge, and seal the floor... Using the RBR energised air skirt idea.
ESPImperium
ESPImperium
64
Marianne has said that is the area she is most proud of, the "lole" the Lower Leading Edge arround the side pods, and the bardge boards.
From what i have learned from the magazine, the main areas of development were the nose, the sidepods and the rear of the car. The roll hoop was designed early on, and signed off in August with the Chassis and nose box.
looking at the pics in F1 Racing, the sidepods are really RB7 eske, flowing down to the floor, and are really clean providing the diffuser with as much of a clean air flow as posible to get as much downforce as posible from the upper side of the diffuser. However its whats below the floor that provides more downforce i know.
From what is said in the article, i can confedently predict this car will be a step forward, and put them in the mid pack.
The speed of development of the car is critical, if they can develop the car quickly enough, and get performance gains, i see no reson that an leap to P8 is capable in the CT01. However i think the team would settle for P9.
aleks_ader
90
Mchamilton wrote:
tok-tokkie wrote:
Isak wrote:High res versions. Right click -> show image to get them in fullsize.
Maybe they want seal with vortices and with huge amound of air (edge on the side of sidepods) leading edge of diffuozor?
raymondu999
Can anyone enhance the part? My eyes aren't powerful enough to make out what you're talking about
失败者找理由,成功者找方法
beelsebob
beelsebob
85
raymondu999 wrote:Can anyone enhance the part? My eyes aren't powerful enough to make out what you're talking about
It's the slant at the front of the floor that we're muttering about :
aleks_ader
90
Mchamilton exact that i have in mind...
raymondu999
The floor actually terminates not on the bottom of the sidepod? Beelsebob doesn't it contravene the "surfaces visible from bottom must be on reference or step plane" rule that you quoted a while back?
失败者找理由,成功者找方法
beelsebob
beelsebob
85
raymondu999 wrote:The floor actually terminates not on the bottom of the sidepod? Beelsebob doesn't it contravene the "surfaces visible from bottom must be on reference or step plane" rule that you quoted a while back?
Yeh, I can't see a reason why it doesn't get caught in that – I'd be interested to see if anyone can spot why this would be legal.
Owen.C93
Owen.C93
191
They had a funky leading edge to their floor last year as well, nothing "special".
beelsebob
beelsebob
85
Owen.C93 wrote:They had a funky leading edge to their floor last year as well, nothing "special".
Last year's sloped on the top, but not on the bottom. It also didn't slope at anywhere near the angle that does.
