We need a plan-view shot, but it looks to me like they've just smoothed out the transition from sidepod to wart.
so there is definate updates on this looks like they have moved the exhaust closer to the wheel as well as intergrating it into the body work wonder wether there is aero benifits to this as wellPup wrote:Looks like the whole sidepod has been slightly reprofiled along with the exhaust...
Maybe, this new package round the exhaust is a lot tidier though, look at the side profile angles, also it appears to help keep the already big undercut even more.Pup wrote:I'm sure it does, but I think it's more a matter of converting a test piece. I'd bet that they did interchange exhaust exits, playing around with subtle changes to the exhaust angles which we just couldn't see. Then once they got it tuned, they went to press, as it were.
I suspect that the main performance change today came from the front end - sending more air around to the diffuser and shifting the balance to the rear.
Owen.C93 wrote:Oooh that's new.
Sorry to single you guys out - no offense meant to either of you. But, typing isn't that difficult, or at least it's far less so than these mini games of 'where's waldo' that you're asking the rest of us to play.mclaren777 wrote:Very interesting.
The guy above me pointed out new sidepods and asked for more pictures so that's why I said that. And isn't it obvious the guy above is talking about the mirrors being in the middle of the car inducing asymmetric aero invented by Newey over a decade ago!Pup wrote:Owen.C93 wrote:Oooh that's new.Sorry to single you guys out - no offense meant to either of you. But, typing isn't that difficult, or at least it's far less so than the mini games of 'where's waldo' that you're asking the rest of us to play.mclaren777 wrote:Very interesting.
So...what exactly is interesting?
They could still lift the nose tip up if they wanted to though. It's not quite the same but will allow for more air underneath.ringo wrote:Mclaren probably wished they had a stepped nose now.
clearly the snow plow was more for frontal downforce. The high underside nose designs are more for putting high energy air in the frontal floor area, increasing central downforce.
Mclaren are going the central downforce route now with the removal of the snow plow, but they could have been a little better off with a slightly higher nose; it would not have hurt their chances.
Though they still emphasized there are suspension benefits with an average height tub.
look at the difference in the overall height profile of the Macca and the Sauber...there's a clear advantage to centre of gravity and over-all effect on the air it disturbs, also I guess this picture shows what a mammoth job it would be if Mclaren did have to raise its noseCrucial_Xtreme wrote:McLaren running without snow-plough
