Vodafone McLaren MP4-27 Mercedes
simieski
simieski
Re: Vodafone McLaren MP4-27 Mercedes
As Holm said, it's just a cradle supporting blowers for cooling the brakes
Thank you to God for making me an Atheist - Ricky Gervais.
Crucial_Xtreme
Crucial_Xtreme
404
Holm86 wrote:What sensor?? All i can see is the brake duct coolers.
Yeah seems you're right. I got the picture & the idea it was a sensor for FW from RaceCar Engineering. Didn't pay too much attention. Dummy me.
http://www.racecar-engineering.com/cars/mclaren-mp4-27/
Rear view mirrors location designed by Hamilton.. http://www.bbc.co.uk/sport/0/formula1/17311228
His engineers didn't want to change the position due to performance concerns but Hamilton insisted, turned out the new position had a neutral effect.
Much much closer to the steering wheel, and very high and angled.
http://www.racecar-engineering.com/wp-c ... pmacca.jpg
MIKEY_!
Hopefully that means less crashing into Massa this season :lol:
raymondu999
n smikle wrote:Rear view mirrors location designed by Hamilton.. http://www.bbc.co.uk/sport/0/formula1/17311228
For those who can't see the video, here:
[youtube]http://www.youtube.com/watch?v=Dx9JowQZrfw[/youtube]
I was quite surprised to be honest. I thought McLaren just copied the RB7 mirrors - which these resemble a lot. But if the engineers didn't bother to test before saying it was a bad design - you sort of have to wonder whether there is an ethos of having preconceived assumptions of what are bad designs and not worth testing - without actually testing them
失败者找理由,成功者找方法
Tim.Wright
330
Crucial_Xtreme wrote:Hadn't seen this picture of the FW sensor at Barcelona.
[img]http://www.racecar-engineering.com/wp-c ... u1.jpg[img]
They are coffee machines. Buttons for on/off and espresso/lungho
Tim
Reason: Removed image quoted from post above
CHT
CHT
-7
Looks like it was used before they fitted the new section under the nose.
it this some sort of wing flex measurement sensor?
myurr
myurr
Aren't they just fans for blowing the brake ducts?
amouzouris
105
yep that's what they are
Reason: Removed quoted post that is just above
Pierce89
60
keep this crap out of the car threads people! [-o<
Mandrake
Mandrake
The neutral effect has surely been calculated upon the loss in performance after running into other cars. Slightly worse aero outweighed by less crashes
ianwit
ianwit
If memory serves me right Hamilton only had one mirrors issue in Japan, the other issues were down to other peoples mirrors or one in particular.
Became a McLaren fan in the late 70's when I ended up laminating their Kevlar nosecones.
Owen.C93
Owen.C93
191
Regarding the neutral mirrors I think this helps show what they've done.
raymondu999
Can we really see where the mirror affects the flow though?
失败者找理由,成功者找方法
scarlet
scarlet
All the picture shows is that the mirrors are high enough to avoid disturbing the air passing beside the nosecone and around/beneath the sidepods - as no flow vis appears on them. What's less clear is any effect further back on top of the sidepods, although I guess this is less important for aerodynamics anyway.
