McLaren won't be using the snow plough in Melbourne. Whitmarsh confirmed they removed it because a lack of rear downforce. He said that if the team recovers a lot of downforce at the rear they may go back the other way(running snow plough) but right now, the development suggests no snowplough is the way to go.mclaren777 wrote:Are there any pictures from Melbourne that clearly show whether Mclaren is using the snowplow or not?
Crucial_Xtreme wrote:McLaren won't be using the snow plough in Melbourne. Whitmarsh confirmed they removed it because a lack of rear downforce. He said that if the team recovers a lot of downforce at the rear they may go back the other way(running snow plough) but right now, the development suggests no snowplough is the way to go.mclaren777 wrote:Are there any pictures from Melbourne that clearly show whether Mclaren is using the snowplow or not?
Exactly. It adds more DF to the front end than people are giving it credit for, that's for sure.Holm86 wrote:
So then its definitely not a negligible amount of frontal downforce the sow plough adds?
People have been talking in here earlier that the snow plough didnt add that much downforce.
Or just enough to imbalance the car.Crucial_Xtreme wrote:Exactly. It adds more DF to the front end than people are giving it credit for, that's for sure.Holm86 wrote:
Autosport magazine wrote:But during the second half of the Barcelona test, McLaren tried out underbody aerodynamic modifications similar to those used by teams with high chassis.
This surprised AUTOSPORT technical correspondent Gary Anderson, who said: “Last year, people started putting the on- board cameras down low behind the centre section of the front wing to make this area into a slight downforce-producing device, combined with vertical turning vanes at the nose-to-chassis interface to accelerate that air.
“McLaren has now gone down this route, which is designed to drag the air through the front-wing central section to the leading edge of the sidepods as fast as possible. This system works far better when you have the maximum chassis height, because it allows you to make these turning vanes taller, giving bigger gains in this area.”
Whitmarsh insists that the modifications to McLaren’s nose and splitter section are not an admission that the concept is wrong, and cites the requirement to maximise rear downforce even with an orthodox nose height.
“We removed the under-nose splitter, which probably enhances the efficiency of the rear end,” he said. “If we get a lot of downforce at the rear end then we may go back the other way, but where we are in the development cycle suggests that this route is beneficial.”
McLaren is set to run this design in Melbourne this weekend.
Right. I think it helps the front, but as you said more importantly robs the rear of airflow/DF. And removing it brings the balance more towards the central part of the car.raymondu999 wrote:I think it's not quite that it just makes so much downforce at the front that it imbalances the car - but that it robs the rear of downforce no? Because the air is worked in front rather than towards the rear; as it were.
Mind - the McLaren nose would probably be better suited to the snowplough; and undernose vanes should theoretically be more suited to high(broken?) noses.
Jef Patat wrote:A peek under the hood
http://www.auto-motor-und-sport.de/bild ... ow_item=66
