Vodafone McLaren MP4-27 Mercedes
ajdavison2
ajdavison2
30
Re: Vodafone McLaren MP4-27 Mercedes
I think this nose makes the car look even better, so much more elegant than the other stepped noses, if you can call this stepped!
aral
aral
26
This is only a cosmetic change. The bulkhead remains at its low height as heretofore, and only the tip of the nosecone has been raised slightly, if at all. It could well be that the only difference is a slightly concave top.
Coefficient
Coefficient
gilgen wrote:This is only a cosmetic change. The bulkhead remains at its low height as heretofore, and only the tip of the nosecone has been raised slightly, if at all. It could well be that the only difference is a slightly concave top.
I think its clear that other dimensions have also changed hence the need to revise the pylons
Nando
Nando
I think that might be it though. Looks to me they have scraped off some carbon on tóp of the nose cone then just raised the front of it.
Possibly made it thinner from the underside as well.
And the obvious pylons.
But i doubt they have done anything to the chassis, looks the same to me, just a modified nose cone.
GrizzleBoy
GrizzleBoy
33
The old nose was pointing down to the floor and would have generated downforce at the tip. The air then gets used over the top of the car.
The new nose tip cuts straight through the air and allows air that would have otherwise been pushed up and over the car to get underneath it.
Can that be seen as only a cosmetic change?
brucci2000
brucci2000
Does anyone else see a second layer below the main plane on the outer section of the wing? Is this real, optical illusion or test gubbins? Was it always there?
Owen.C93
Owen.C93
177
brucci2000 wrote:[img]http://img1.auto-motor-und-sport.de/McL ... 80.jpg[img]
I don't see what you are talking about.
n_anirudh
n_anirudh
Yes..it does appear to be a two layered wing..but i hope its not an illusion of the leading edge thickness
Robbobnob
Robbobnob
33
i believe it is the reflection of the road on the leading edge.
if it were a two layered wing it would breach the minimum radius would it not. a picture with better colour depth would clarify this
Nando
Nando
It´s one solid piece from what i can see. Left side shows that it´s just a thick piece of carbon.
bhall
bhall
244
It appears to be the tea tray.
aral
aral
26
bhallg2k wrote:It appears to be the tea tray.
Yup! You can even see the shadow.
silversurf3r
[/url]http://www.f1fanatic.co.uk/2012/05/09/m ... pain/"[url]
MW says Mclaren likely to run high nose at Barca.
brucci2000
brucci2000
Thanks for clearing that up - just one of those strange alignments in a picture. The complex surfaces of the cars can lead to all sorts of illusions on 2D photos - especially when they paint most of it in chrome!
gray41
Lewis Hamilton #44
2016
Poles: *****
Wins: ***
