Vodafone McLaren MP4-27 Mercedes
beelsebob
beelsebob
85
Re: Vodafone McLaren MP4-27 Mercedes
Owen.C93 wrote:
hardingfv32 wrote:
Owen.C93 wrote:One thing that I missed in this image was the duct they use for the extra cooling (and no doubt a bit of aero benefit) which exits at the beginning of the sidepods. I first found a shot of it in 2010 but never could find it again. It's out of focus here but you get the idea.
Can you provide a little more detail about the duct's location, I do not see it.
Brian
Black carbon at the top of the rad on the far left. Here's an image without it: http://www.formula1.com/wi/sutton/2012/d12esp314.jpg
I don't see what you're referring to -ย could you highlight it?
Crucial_Xtreme
Crucial_Xtreme
404
Owen.C93 wrote: Black carbon at the top of the rad on the far left. Here's an image without it: http://www.formula1.com/wi/sutton/2012/d12esp314.jpg
Ownen are you talking about the rectangular slot on top of the sidepods just past the inlet? Similar to what RB use?
edit: Like in this picture. Drivers left. At least that's what I think he's talking about.
Owen.C93
Owen.C93
177
Yes, that hole.
f1motta
f1motta
64
McLaren: Adjustable rear brake ducts - system development http://www.f1talks.pl/2012/05/16/mclare ... velopment/
Crucial_Xtreme
Crucial_Xtreme
404
Interesting that Lewis & Jenson ran different brake setups in Spain. I wonder if the adjustable brake ducts played a factor in Jenson's performance, or lack thereof?
Lewis's car on left
via @russellbatch
gray41
Jenson changed to Lewis brakes on saturday morning though?
Lewis Hamilton #44
2016
Poles: *****
Wins: ***
SiLo
139
ell66 wrote:
SiLo wrote:[img]http://i646.photobucket.com/albums/uu18 ... 57.jpg[img]
Clearly different philosophies of how to utilise the front wings...
Just realised the lines are hard to see, but they are there!
thats a terrible comparison, and not only that but vettels front wing is clearly broken here.
The general planes of the wings are not broken, so the comparison is good thank you very much. It highlights how much the RB wing twists compared to the Mclaren wing in a corner.
Felipe Baby!
SiLo wrote: The general planes of the wings are not broken, so the comparison is good thank you very much. It highlights how much the RB wing twists compared to the Mclaren wing in a corner.
It is a decent comparision and does show the RB flexing a bit more, although the fact that Vettel here in this picture is further on track being more in the braking zone(it seems), he also has his front suspension compressed more, thus running the wing closer to the ground.
Apart from that, we know that the McLArens are running very stiff, mainly on the front. Thus maintaining a more constant front ride height.
All this distorts the 'truth' in the picture due to different suspension settings as well as track position
Nando
Nando
Looks like both are well out of the braking zone.
Check the steering angle and where they are on track.
they are also carrying different speeds due to it being 2 lines through the corner.
Also notice that the Mclaren nose is just as high if not higher than the RB8 nose.
aral
aral
26
n smikle wrote:Also notice that the Mclaren nose is just as high if not higher than the RB8 nose.
The two cars are at different elevations and angles to the camera, so there are bound to be apparent differences. Thankfully, all cars are not the same, and different teams are able to design different cars, and long may it continue.
Owen.C93
Owen.C93
177
SiLo wrote:Image
Again just highlighting the different philosophies where RB bend their front of the wing down to add more pitch at high speed where as McLaren bend it back and lower the AoA.
Different angles.
Owen.C93
Owen.C93
177
n smikle wrote:Different angles.
Luckily the front wing end plate and floor are parallel.
SiLo
139
Thank you Owen :) the differences in angles, eleveation of the cars, part of the corner etc will have negligible effects on the relative angles of the wing and floor.
Also, Do Mclaren run a stiff front and soft rear? It seems that other teams run a soft front and stiff rear to keep their desired rake. Just my two cents there though :)
Another question, does the plane of the front wing have to be parallel to the floor?
Felipe Baby!
