Vodafone McLaren MP4-27 Mercedes
CjC
CjC
Re: Vodafone McLaren MP4-27 Mercedes
Cheers Owen.
I think he means the amount of redesigning rev bull have done on their exhaust, they hav had a new solution every race
Just a fan's point of view*
Holm86
261
Coefficient wrote:The car is suffering because their trick floor was taken away. They can't run the same rake they used to as a result and therefore the whole package is compromised. The higher nose would allow them to experiment with more rake again and if they don't try it they might as well resign themselves to having a bad season and start on next years car. The loss of the floor has had a domino effect because they are now struggling to produce enough rear downforce which is having a knock on effect on tyre wear. The extra flow under the car that the higher nose would provide would definately give them something to work with with a view to improving other areas of the car whereas at the moment they've hit a development cul de sac.
What floor?? I didnt know that McLaren had a floor that was deemed illegal?
Coefficient
Coefficient
Yep, I’m afraid they did and they were told to change it earlier in the season.
As it is very difficult to manufacture a perfectly flat floor the technical regulations allow for up to 3mm worth of imperfections to account for manufacturing issues. Mclaren started the year with a floor that was deliberately designed to take advantage of the 3mm tolerance within the regulations. The floor essentially began to angle upwards 60cm back from the front lip of the bib splitter effectively enlarging the diffuser and creating rake without rake if you take my meaning. The team argued the floor was within the 3mm tolerance and was therefore legal whereas Charlie argued they were taking the urine and made them modify the car. The team were clearly aware of the contentious nature of the trick floor because they had a flat one ready to bolt on immediately should it be challenged.
astracrazy
astracrazy
31
Coefficient wrote:
Holm86 wrote:
Coefficient wrote:
which looking back now to the release of the mp4-27 was what mclaren meant by some people may find our car illegal - this was it
Holm86
261
Didnt know that. Do you have a source? Havent seen this being discussed here before??
Coefficient
Coefficient
Didnt know that. Do you have a source? Havent seen this being discussed here before??[/quote]
The source was Autosport Magazine. It was the F1 editor's editorial, I believe he's called Mark Hughes. I'll try and find it on the net and post a link but I'm old school and buy the paper version from the papershop.
I had heard about that tricky floor, but didn't how it was implemented.
As always, ingenious and dodgy at the same time.
CjC
CjC
Yep coefficient Is spot on about the floor, wasn't it in Bahrain when it had to be taken off?
Huntresa
Huntresa
CjC wrote:Yep coefficient Is spot on about the floor, wasn't it in Bahrain when it had to be taken off?
China i believe
hammarby88
hammarby88
I was under the impression that the floor was angled upwards in the front? Thus meaning that they could run with more rake but still have a very low ride height since the front of the floor was bent up slightly.
kalinka
kalinka
Owen.C93 wrote:I'm not sure why he says that RB did a large redesign for it though.
From article on the fron page on this site > "Red Bull adopts Helmholz exhaust chamber" >
"To make room for the exhaust chamber that Ferrari debuted in F1 through 2011, RBR redesigned the entire exhaust of the RB8. While it previously ran close to the car's engine heat cover and then curved downward with a 180° turn, the final turn is now curved upwards, similar to Williams' exhaust layout."
It's just suspicious for me , that the currently strongest two designs all incorporate that type of exhaust. So it must be a true benefit , especially seeing that RB had to do quite a lot of redesign. So I wonder is it possible to do that on the Merc enginge too - and is it any possibility that we could see that in Germany already on the McLarens ?
Pup
Pup
50
Update for Germany: hydroplated coach pins with sub-retinal handling compensating...
[youtube]http://www.youtube.com/watch?v=Ld8-VW-0D2M[/youtube]
Coefficient
Coefficient
hammarby88 wrote:I was under the impression that the floor was angled upwards in the front? Thus meaning that they could run with more rake but still have a very low ride height since the front of the floor was bent up slightly.
It's the same thing. The suspension is set to allow the bib to run flat/parallel to the floor therefore the V shaped floor increases in height rearwards. The floor allowed Mclaren to achieve the effect of rake without the compromises in suspension geometry assosciated with simply jacking up the rear ride height and lowering the front. It was a double win in that respect and this is also why we see them introducing revised rear suspension components because they too were compromised with the technical clarification.
raymondu999
Here: http://www1.skysports.com/formula-1/new ... me-undone-
Happened in China
失败者找理由,成功者找方法
Owen.C93
Owen.C93
191
Ferrari have ran it since 2011 and haven't been dominant and redbull were stronger in the last race without it so I wouldn't say it's a must have type of deal.
