I thought you knew high nose was coming?n smikle wrote:They will be bringing "special" updates to ensure Hamilton victory for his 200th GP.
All I know is that the emphasis is on "special" So prepare to see something "special"
It's probably delayed againOwen.C93 wrote:I thought you knew high nose was coming?n smikle wrote:They will be bringing "special" updates to ensure Hamilton victory for his 200th GP.
"McLaren have new sidepods that are "quite different" for German GP this weekend, team boss Martin Whitmarsh says @andrewbensonf1 18 minutes ago"n smikle wrote:They will be bringing "special" updates to ensure Hamilton victory for his 200th GP.
No he's right... Mclaren will be bring the stepped nose/ raised chassis in another 100 races...raymondu999 wrote:When did he sprout another 100? Did he inherit them somewhere?n smikle wrote:They will be bringing "special" updates to ensure Hamilton victory for his 200th GP.
If mclaren and lotus bring a similar update that gives them both a similar amount of laptime and remarkably jumps them into the lead, then lotus will b winning the races...f1316 wrote:"McLaren have new sidepods that are "quite different" for German GP this weekend, team boss Martin Whitmarsh says @andrewbensonf1 18 minutes ago"n smikle wrote:They will be bringing "special" updates to ensure Hamilton victory for his 200th GP.
Scarbs has been talking about the possibility of Lotus and McLaren having sidepods with tunnels, much like an inverted U-Pod, with the gap at the bottom. It's just speculation, but sounds very interesting if true.
astracrazy wrote:so they could be more or less going with Toro Rosso style sidepods in terms of the undercut?
Well, McLaren themselves are saying it's a big visual change to the sidepods, so....gray41 wrote:Its clearly just going to be another refinement, perhaps different cascades on the FW inline with side pod differences maybe splitting the floor at the front to control the airflow under the car better?
Yes, and Lotus called their updates "interesting", which is lanaguage not usually used for refinements.PhillipM wrote:Well, McLaren themselves are saying it's a big visual change to the sidepods, so....gray41 wrote:Its clearly just going to be another refinement, perhaps different cascades on the FW inline with side pod differences maybe splitting the floor at the front to control the airflow under the car better?
I doubt they will have a double floor concept. If the rumours of tunnels are true I think it is more likely to be an extreme version of Red Bull's tunnel starting from the front of the sidepod. The STR concept clearly isn't working well enought to offset the C.O.G issues it creates so Mclaren are unlikely to do that IMHO. Happy to hold my hand up and admit buffoondom if I'm wrong but STR have had flow attachment issues with their concept so Macca would be brave to try it.matt_b wrote:I suspect it will something very similar to what Torro Rosso have, as McLaren cannot raise the chassis during this season(which offers more aerodynamic improvement). Instead they have to find other solutions to get more airflow from the front of the car to the rear diffuser, the Torro Rosso style fits this solution. Should be interesting to see what else they have brought along.
