only if it is damaged or when they can prove it is about to failbanibhusan wrote:What I don't understand is why FIA might impose the parc ferme rule. The parc ferme rule applies to all the cars after qualifying till the race starts. I understand they are allowed to change a part with an exact similar replacement, but would they be allowed to change a whole gearbox(same gear ratios off course) no matter what the problem is? If not then the parc ferme rule will be applied by default and he has to start from the pit lane. Ferrai wouldn't mind that either I guess!!
that is why Scrabs is suggesting, if they do it without any reason they will be deemed as breaking the parc f rule and hnce start from the pit lane
