Mercedes AMG F1 W04
Mika1
Mika1
Re: Mercedes AMG F1 W04
Guys, we need some pics of the Merc this afternoon. According to Auto Motor und Sport it took some time this morning to change some parts.
The boss follows me on twitter.
Mika1 wrote:Guys, we need some pics of the Merc this afternoon. According to Auto Motor und Sport it took some time this morning to change some parts.
Jep, they said "some bigger Changes" actually. Could be Interesting, since they want to test Stuff today with 80% chance of Rain tomorrow.
dren
226
I read it was mainly sensors and monitoring devices that took time to install/remove.
Honda!
OO7
OO7
171
Yesterday Lewis ran with the FDRS installed, which is designed to stall the centre of the rear wing. Would it be possible to have a similar device fitted to the rear wing end-plates, that blows inwards out of holes/slots on the inside of the end-plates to stall the outer portions of the rear wing?
Perhaps the regs prohibit 'holes' in the rear end plate body work region?
andrewf1
228
Blaze1 wrote:Yesterday Lewis ran with the FDRS installed, which is designed to stall the centre of the rear wing. Would it be possible to have a similar device fitted to the rear wing end-plates, that blows inwards out of holes/slots on the inside of the end-plates to stall the outer portions of the rear wing?
The outside is almost impossible to stall. The flow is very attached on the back of the wing and end plate there. Also the upwash is greatest on the outer edge.
It would take tremendous amounts of momentum energy.
It's easier to stall the weakest flow on the wing, which happens to be in the middle. This flow is the weakest and most sensitive.
228
Ferrari has a solid single profile towards the inside of the tyre. Mercedes on the other hand simply have 5 profiles.
think they'll close off some of the gaps between the elements on the inside?
It looks like a very skilled technique to mold ferrari's wing though.
OO7
OO7
171
Thanks ringo.
lewishamilton90
lewishamilton90
-1
long run very good for nico
Ferraripilot
21
ringo wrote: Ferrari has a solid single profile towards the inside of the tyre. Mercedes on the other hand simply have 5 profiles.
http://img1.auto-motor-und-sport.de/Nic ... 663052.jpg
I believe mercedes are using the inboard front wing slots to feed the sidepods/barge boards as opposed to most everyone else who include inboard slots on the 3rd or 4th elements only largely leaving the main plane alone. And I'm not certain of this bit yet but it may be possible Merc's solution runs more rake on the front wing as well which is probably specific to this different design philosophy.
Huntresa
Huntresa
zonk wrote:[youtube]http://www.youtube.com/watch?v=aSNwwFPAhfo[/youtube]
Why are you posting old stuff that was posted like 15 pages back?
Pandabeer
Pandabeer
Maybe he didn't know that it was already posted. Just ignore it if you already know it, otherwise enjoy it.
Barcelona Session 1 - Day 3 (21.02.2013)
Ferraripilot
21
Thanks for the pics. The dip in the floor is not quite in focus but it's certainly larger and deeper than I previously imagined it to be.
Shrieker
Isn't the coanda exhaust supposed to blow inwards where the flo-vis is ? Yet it looks like the paint has barely moved.
What's your take on this guys ?
Also... Is that flow seperation on the last pic ?
-Atatürk
