Sauber C32 Ferrari
henra
henra
53
Re: Sauber C32 Ferrari
Artur Craft wrote: On another note, following the exhaust's marks, you can have an idea of roughly where the plume is going:
Yes that is clear to see. And it seems to confirm a bit my concern/confusion about how the airflow around the sidepod would work with blowing the diffuser. The air moves mostly along the sides of the sidepods rather than over it blowing the plume inward rather than downward. I'm curious to see if there will be a version 2.0 of their sidepods / exhaust bulges soon. As it is I highly doubt they will achieve a significant blowing of the diffuser edges.
The exhaust are pointing outwards, with the airflow going inwards. That compensated alot already. Also the exhaust is inside a bulge, which does reduces the inward redirection somwhat.
henra
henra
53
turbof1 wrote: The exhaust are pointing outwards, with the airflow going inwards. That compensated alot already. Also the exhaust is inside a bulge, which does reduces the inward redirection somwhat.
The problem is that the plume doesn't really seem to follow the coanda ramp properly. McLaren, Ferrari and others use the flow over the sidepods to support the plume following the ramp. It seems this support is missing in this case. The plume appears to move mostly horizontally and inward. However, that is not what is generally considered as ideal for blowing the diffuser and somewhat resembles what RB was fighting against at the beginning of last season.
Lower resolution version of some pictures from the other page.
Barcelona (Test 3, Session 2) - Day 2 (01.03.2013)
Artur Craft
40
henra wrote:The problem is that the plume doesn't really seem to follow the coanda ramp properly. McLaren, Ferrari and others use the flow over the sidepods to support the plume following the ramp. It seems this support is missing in this case. The plume appears to move mostly horizontally and inward. However, that is not what is generally considered as ideal for blowing the diffuser and somewhat resembles what RB was fighting against at the beginning of last season.
The plume is going inward but I wouldn't say they are going horizontally. It seems to be going down quite fine because otherwise you wouldn't see marks where they are as regulations mandate the pipes to point upwards
Nando
Nando
Probably the best image showcasing just how tight they are, (imo)
Paul
Interesting that slots near the side pod entrances are of different length. Either it's for comparison purposes, or due to different cooling needs for components in each side pod...
Oil radiator/water radiator
Forza
238
F1 Test BCN T03 - Day 3
Barcelona (Test 3, Session 2) - Day 3 (02.03.2013)
High resolution: Back end/exhaust | Sidepod inlet/bargeboard | Wheel hub | Front
Artur Craft
40
There was a good stint by the car today(17 laps with 1,4s drop from 1st to last) but unfortunately Ferrari's tire problem ruined the progression of those stints
Tomorrow is the "this is it" day. I'm eager to see what they can do on race simulation
PS: anybody noticed any new bit on the car?
Forza
238
F1 Test - BCN T03 - Day 4
Barcelona (Test 3, Session 2) - Day 4 (03.03.2013)
via Craig Scarborough
Mui
Mui
Has anyone noticed the large hole behind the drivers helmet beneath the airbox ? anyone know what its for?
beelsebob
beelsebob
85
Mui wrote:Has anyone noticed the large hole behind the drivers helmet beneath the airbox ? anyone know what its for?
Cooling of some sort.
