That does not necessarily have to be a contradiction: The optimum temperature window of the Tyres is said to be very narrow.kooleracer wrote:And btw Q3 the track temp was 42 Celsius and on Sunday it was 42 celsius. So Merc was quickest when it was the hottest in Q3. So explain that me please. Same temp but quickest if Q3, if the car doesn´t like the heat how can it be fastest in the heat?
On one lap with a low fuel load high track temps could help you get into the window from below where other cars with a less aggresive Tyre heating behaviour might struggle to get the Tyres hot enough.
Running heavy over multiple laps, the same track temperture could easily get you out of the window on the high Temperature side of things.
One thing I was wondering is if we have any idea about the fuel tank design of the W04. Is it maybe particularly high or susceptible to sloshing or maybe not ideally placed close to the CG so that the balance or roll characteristic changes more significantly than others when the fuel load changes. Thereby exacerbating said higher fuel consumption and thus weight.
Regarding the fuel weight difference I have to admit that I'm struggling a bit with the purported 15kg or even 20kg.
We can probably safely assume that the Power differences between the different F1 Motors are not more than 10 to 20 HP.
A Fuel weight difference of 15kg would be almost a whopping 10%. That's really huge for IC engines of pretty similar era, design and construction.
In Road vehicle design it takes multiple engine generations to find 10% efficiency in an IC engine of comparable basic design. I would be surprised if such differences existed in F1.
