Williams FW35 Renault
Seamus
Seamus
Re: Williams FW35 Renault
btw. FW31 was at Silverstone..
drunkmunky wrote:That's the montreal wing...
We are talking front wing, you can see that it's smaller than the current max width like the 2014 rules dictate, the front tyres should offer a nice reference.
The rear is Montreal no doubt.
And it's not the FW31 FW.
Huntresa
Huntresa
Seamus wrote:
Sevach wrote:http://motorsport.nextgen-auto.com/gall ... ul/074.jpg
A 2014 spec FW?
Seems smaller than the max.
it's looks like FW 31 front wing
http://upload.wikimedia.org/wikipedia/c ... _wings.JPG
http://www.formula1.com/wi/full/ta_arti ... le_667.jpg
maybe this is the concept of 2014
http://i196.photobucket.com/albums/aa12 ... 70x313.jpg
FW30-31
http://scarbsf1.com/blog1/wp-content/up ... _draft.jpg
ScarbsF1.com - 2014 Rules: First Look
Its not even close to looking like that wing...
White_F1
White_F1
I've made some calculations measuring the distance between wing tips and it looks like an optical effect. Wing width is 180cm, 2013 size.
The rear wing is suppoused to 75 cm, which by your pixel count would make the FW bigger than the maximum allowance.
White_F1
White_F1
Yep, 75cm including endplates. The flaps may be up to 71cm width, maybe the arrows in the picture are not accurate enough ;). Anyway, it's a 2013 front wing in my opinion.
hollus
Perspective effect. The front wheels are, in that picture, further appart than the rear wheels, telling you that the lens has not nullified perspective effectS. The front wing, even closer to the camera, appears much bigger than it is, so measuring pixels is misleading.
TANSTAAFL
White_F1 wrote:Yep, 75cm including endplates. The flaps may be up to 71cm width, maybe the arrows in the picture are not accurate enough ;). Anyway, it's a 2013 front wing in my opinion.
You know the endplates are fin layer plate right, it has nowhere near 4 cm of width.
And btw you did measure from endplate to endplate, how did you assume that would be 71 cm i don't know...
You have every right to your opinion just don't spout incorrect "facts".
White_F1
White_F1
I just wanted to make some calculations to help checking the size of the wing, but as hollus said, perspective is making them useless.
I'm sorry if it looked like I wanted to spout out incorrect facts, that was absolutely not the point of my post.
Btw, since technical regulations state that rear wing flaps can't go further than 355mm each side of the car center line, that's what I tried to measure (without endplates). I know that wing measures are not the point of the thread, so I'll check it back and try to be clearer next time.
Anyway, thank you for helping me understanding the mistakes in my calculations.
Hungary 2013 - Thursday (25.07.2013)
roadie
39
So the blown nut is gone?
I think so, yes.
The brake ducts are still quite big which confuses me however, in Monaco Pastor had last year tiny ducts without the blown nuts.
Did they abandon them because of pit stops? Or because they don't bring the expected gain?
LookBackTime
LookBackTime
472
I see some slots on the engine cover!
boyracer94
boyracer94
Sevach wrote: I think so, yes.
Apparently a large part of the decision was based on their poor pitstops
roadie
39
Hmmm, let's see if pit stop times improve...
