btw, if it indeed is correct the engine can't perform above 75%, and regarding the electronic [cooling] issues......and the said 20 weeks timescale......what will happen?
surely the teams cant run a faulty engine that can't perform above 75%? let's say the electrical issues are possible to fix before bahrain, and they can make a running car - if the 75% figure sticks, then they'll fall outside of the 107% rule so they can't even start !!
worst case scenario: the engines can't be fixed earlier then 20 weeks from now.....what will happen?
