Lotus E23 Mercedes Speculation Thread
Re: Lotus E23 Mercedes Speculation Thread
you know what, this car looks actually quite fast. It looks much more 'balanced' compared to the aero of last years barbeque-stick, which would have created many 'odd' aero patterns.
this looks much 'smoother' and more 'stable' in the way it directs air around the body.
Really interesting approach with the turbo-feed.
Vary
Vary
Sevach wrote:
Vary wrote:Optical effect or the rear wing pylon is "asymmetric" like last year?
It's fixed to the engine cover like the RB10.
Oh yeah, just looked a bit more carefully alla images... Stupid me! :evil:
Edit: Aldo noticed that the rear wing is probably just a generic one, doesn't eventi nave DRS actuator
ScottB
ScottB
What's with all the air box cooling? Seems a bit much? Unless they've come up with something... crafty?
The narrow nose suggests a complete different philosophy, reducing blockage at the sides, suggesting they want to get the airflow around the nose directed underneath the chassis.
turbof1 wrote:The narrow nose suggests a complete different philosophy, reducing blockage at the sides, suggesting they want to get the airflow around the nose directed underneath the chassis.
Lessons learned from that test nose in 2014 perhaps.
FrukostScones
163
ScottB wrote:What's with all the air box cooling? Seems a bit much? Unless they've come up with something... crafty?
is it for intercooler cooling? or what else could it be?
car looks chunky and reminds me of 2014... :| Nose looks to slim to look good. rw pylon seems still to be rubbish...
frosty125
frosty125
Way more than just for oil coolers so I think a inter-cooler.
they had ears on the 2014 car, like a F-duct. I assume it's for the intercooler/cooling, as the Williams also hage a much bigger cooling opening compared to the 2014 car. The supposed Ferrari intake looks a lot bigger, too; suggesting all cars will feature something similar.
I agree however it seems the Lotus has the biggest solution as it seems.
Perhaps 1 is for actual cooling and the other one has another goal (F-duct after all?)
gray41
Detail of the roll hoop intakes, adjusted to see better.
Lewis Hamilton #44
2016
Poles: *****
Wins: ***
atlantis
atlantis
21
The front suspension seems very agressive.
The lower element is very high to clear the airflow
FrukostScones
163
maybe alien intake won't feature on the actual car and is just a deception...
slimfitcasual
Nice. Side view looks down right MEAN.
I wasn't aware Total dropped Lotus, wasn't that a Romain deal?
Per ardua ad astra
FrukostScones
163
I name it "the black widow".
OO7
OO7
171
Good point. The nose tip regs only stipulate 40mm width worth of 'blockage', so Lotus had a little bit of freedom beside the nose tip that they have chosen not to use. This could indicate a different philosophy or a temporary launch spec only nose.
dmjunqueira
21
The camera pods are missing on these images...
