Williams FW37 Mercedes
LookBackTime
472
Message from turbof1!
This is the official Williams FW37 Mercedes car topic. Any discussion about the technical aspects of the car belong here.
Some ground rules:
-Discussion about the car ONLY. Talk about drivers or engineers belongs in the team thread.
-Discussion about sponsors, partnes and livery also belong in the team thread. However, if a technical partner delivers a product that directly goes into the car, then that is allowed here as long it's solely about the car. For instance Shell developing a new lubricant.
-Comparing laptimes belongs in the respective race or test thread.
-Speculation is NOT allowed. Discussion is limited purely to "what you can touch and see", about the psysical parts on the car.
-Moderators can split topics when they see fit.
Any posts failing these simple guidelines will be removed! Repeating offenders will receive action.
LookBackTime
472
Re: Williams FW37 Mercedes
FW37 Technical Specifications
Chassis construction Monocoque construction laminated from carbon epoxy and honeycomb surpassing FIA impact and strength requirements
Front suspension Double wishbone, push-rod activated springs and anti-roll bar
Rear suspension Double wishbone, pull-rod activated springs and anti-roll bar
Transmission Williams eight speed seamless sequential semi-automatic shift plus reverse gear, gear selection electro-hydraulically actuated Clutch Carbon multi-plate
Dampers Williams
Wheels Aptech forged magnesium
Tyres Pirelli, Fronts: 245/660-13, Rears: 325/660-13
Brake system AP 6 piston front and 4 piston rear calipers with carbon discs and pads
Steering Williams power assisted rack and pinion
Fuel system ATL Kevlar-reinforced rubber bladder
Electronic systems FIA SECU standard electronic control unit
Cooling system Aluminium oil, water and gearbox radiators
Cockpit Six point driver safety harness with 75mm shoulder straps & HANS system, removable anatomically formed carbon fibre seat
Power Unit Mercedes-Benz PU106B Hybrid , Internal Combustion Engine :
Capacity 1.6 litres, Cylinders Six, Bank angle 90, No of valves 24,
Max rpm ICE 15,000 rpm, Max fuel flow rate 100 kg/hour (above 10,500 rpm)
Fuel injection High-pressure direct injection (max 500 bar, one injector/cylinder), Pressure charging Single-stage compressor and exhaust turbine on a common shaft, Max rpm exhaust turbine 125,000 rpm
ERS Mercedes AMG HPP
Dimensions & weight Weight: FIA Minimum, Overall length: 5000mm Overall height: 950mm, Overall width: 1800mm
LookBackTime
472
LookBackTime
472
Double floor not quite so pronounced this season.
Sidepods a bit bigger than i expected from the render.
Nose vanes are new.
triptube
Contact:
2015 Winter testing | Session 1, Day 1 - Jerez de la Frontera, Spain (01.02.2015)
roadie
39
A few things I have noticed.
The sidepod undercut is much less pronounced compared to the FW36.
There is a bulge under the Martini logo at the rear of the engine cover. I wonder if the team has moved some cooling capacity to that region near the car's centreline in order to slim down the sidepods?
The cooling exit vents behind the driver's head have also reappeared.
I am really excited for this car!
Tricky airbox wing.
Hot air exit much much smaller.
As Roadie said quite the lump at the Martini logo.
SectorOne
Not sure if it´s simply the color but the sidepods looks quite large in comparison to what other teams have shown us by now.
They remind me of Sauber´s massive pods last year.
AnthonyG
38
Sevach wrote:Tricky airbox wing.
Was allready there last season.
FrukostScones
162
LookBackTime
472
Alexgtt
No blown front axle, just like Merc.
