Have fun with your ERS/KERS/Shaft Turbine hybrid system versus someone's electric supercharged V10 2-stroke.
That´s true, it would be much better with a fuel flow limit as they could increase power if they manage to increase efficiency, agree. So my engine rules will bewuzak wrote:Hmmm....how are you going to enforce a maximum 1000hp?Andres125sx wrote:Engine rules:
- Max 1000hp
- Max 30 Million per engine
- Max 100kg fuel per race, this limit will go down season by season to encourage ERS development
That´s it, no need for more restrictions, let the teams decide what´s the best posible config. Engineers battles are exciting, at least we´d see some battle in F1
The fuel flow limit will do far more to encourage ERS development than the race fuel allowance because it directly affects power.
I'm completely with you on this one with one addition. Some kind of cost cap should be implemented. How about for every buck you spend too much you have to integrate penalty weight into your design?CBeck113 wrote:Don't be so complex with this, that is why F1 is in its current decline.
Rule 1: tanks for 100kg fuel must be in the car, refueling via shoulder tank (NASCAR) is allowed.
Let'em go at it...you'll see how quickly the teams find a balance between power and efficiency.
As much as you need to win the race with the tyres Pirelli gives you.wuzak wrote:How much power do you think they need?PlatinumZealot wrote:ENGINE TYPE AND LAYOUT
Fuel flow limit: 220kg/hr
What? More power allowed but the same fuel limit? Viewers prepare for cruising and granny shifting half way through the race!Andres125sx wrote:Engine rules:
- Max 1000hp
There is no way to reliably measure the power directly of an engine in a running car. lol. Unless you plan to stick on a few load cells and hope they don't fall off the drive-shaft.Blanchimont wrote:You simply measure the torque and rpm at the driveshafts with standardised sensors, as it's done in WEC for the balance of performance.wuzak wrote:Hmmm....how are you going to enforce a maximum 1000hp?
Who said all the power must come from the ICE?PlatinumZealot wrote:What? More power allowed but the same fuel limit? Viewers prepare for cruising and granny shifting half way through the race!Andres125sx wrote:Engine rules:
- Max 1000hp
So only reason for overtaking is power differences, aerodynamics have no influence, different gear ratios have no iinfluence.... After all, spec series like GP2, GP3, FE, or karting are boring series with no overtakings, no battles... oh wait...PlatinumZealot wrote:There is no way to reliably measure the power directly of an engine in a running car. lol. Unless you plan to stick on a few load cells and hope they don't fall off the drive-shaft.Blanchimont wrote:You simply measure the torque and rpm at the driveshafts with standardised sensors, as it's done in WEC for the balance of performance.wuzak wrote:Hmmm....how are you going to enforce a maximum 1000hp?
Where is the fun in everybody having the same exact horsepower. God, no one passes on the straights! lol
