AlainProst wrote:PlatinumZealot wrote:Different side pod shape, different cooling exits and horizontal louvers at the bottom of the rear wing endplate to name a few aero changes.
No, just have a look on F14-T and SF15-t and you will see that side pods shapes are the same. After that, have a look to MP4-30 or RB 11 above and look who narrow are sidepods. Ok, cooling exits are a little closer than last year but it's not as significant than on the Lotus for example.To finish, horizontal louvers are a detail of aerodynamic and this probably not going to give them a big advantage I think.
Also total new diffuser and its side panels around rear tire, new tire squirt cutouts. That is quite significant change in rear design philosophy.
Plus new front pullrod "Y wishbone" and hidden trackrod layout. If you put all together it is quite a step foward. I will say normal evolution of the car. In 70s this car will definitely get the F14T-B mark.
