Lotus E23 Mercedes
AlainProst
AlainProst
-13
Re: Lotus E23 Mercedes
Do you think the Jerez front wing is the final front wing for the car ? I say this because it's the same than in 2014 and it seems to me it's very different of others front wings in others teams. In fact it's composed by 2 large flat surfaces and after there is 2 small and slim wings. It's very different from Mercedes or Red Bull who have many surfaces (6 or 7 ont the end of the wing) isn't it ?
korzeniow
korzeniow
Yes, it will definately change. Even putting aside the fact that it is way underdeveloped, the first and second tests are all about reliability so teams usualy run some last year parts, not to unneceserly waste time on producing the new ones
Expect teams focusing on long runs this test is Barcelona, at next we will see actual race parts
February 5, 2013
Segmented bargeboard
matt21
86
kwanchepan
kwanchepan
Blackout wrote:Segmented bargeboard
http://cdn-0.motorsport.com/static/img/ ... f1-e23.jpg
2015 Winter testing | Session 2, Day 1 - Circuit de Catalunya, Spain (19.02.2015)
AlainProst
AlainProst
-13
It's surpirsing that Lotus has so small cooling exits this year ! Probably smaller than Mercedes or Williams I think !
Barcelona Test - Day 2 - Friday - 20/2/2015
Via AMuS
emmepi27
emmepi27
141
Mercedes power unit installation on Lotus E23 (ph @motorsportech )
Crucial_Xtreme
Crucial_Xtreme
404
Very interesting that Lotus isn't using the log type exhaust with the Mercedes PU. I wonder if for some reason Mercedes themselves aren't using the log in 2015..
Crucial_Xtreme wrote:Very interesting that Lotus isn't using the log type exhaust with the Mercedes PU. I wonder if for some reason Mercedes themselves aren't using the log in 2015..
Wasn't there already a statemend from Andy Cowell that Merc doesn't use the Log Exhauste in 2015 anymore?
Edit: http://www.f1technical.net/development/461
240
They definitely would have more power this year with that alone..
I guess they realized that in that area they had sufficient airflow underneath the engine cover and could go with a well packaged manifold.
I believe once the manifold is well insulated it should keep the thermal benefits of the log manifold.
And correct me if i'm wrong, but it could be possible that Mercedes does not permit any modification to any part of the PU, such as the exhaust manifold. Any deviations would just mean less correlation across data collected by the customer teams.
emmepi27
emmepi27
141
Another one, much clearer (always @motorsportech)
