Red Bull RB11 Renault
Re: Red Bull RB11 Renault
2015 Winter testing | Session 2, Day 2 - Circuit de Catalunya, Spain (20.02.2015)
bucker
bucker
stefan_ wrote: Image
Steering wheel? :wtf:
Rikhart
Rikhart
38
Its a simple version the mechanics use, the real ones are kinda expensive.
FrukostScones
LookBackTime
LookBackTime
472
Craig Scarborough ‏@ScarbsF1
Someone's parked a @redbullracing on London embankment!
lio007
327
Nice "wallpaper" on the steering wheel ;-)
DAMNINice
37
looks like the "wallpaper" displays the short nose version ;-)
REal men play with twins!
CBeck113
CBeck113
51
[quote="FrukostScones"]Image
I noticed the cutout for the teatray, and cannot understand how the FIA can't deduct that this is purposely made to move. If they only wanted to protect it mechanically then the forward slot for an upward movement of the tray would be enough. But the same distance to the rear? That has nothing to do with installation of the cover or tolerances, that is done to allow the tray to actuate/tilt downward.
For pit stop practice when a mechanic "drives" the car, they just need to be able to hold the front wheels steady. The race wheels are shaped to the drivers' hands and are expensive items so using a simple, cheap alternative is probably sensible.
Caerdroia
Caerdroia
Haven't seen it mentioned but regarding the flowvis on the helmet: Ted said on his notebook that the little wing/flap on the back of the helmet was actually preventing air getting into the cooling hole below the airbox. They've removed the flap off the helmet which means the helmet is now generating a small amount of lift, but the drivers said it was acceptable.
SRK
SRK
Empty space under gearbox is really amazing.
Hmm. Seems the elliptical side-pod was already optimized from last year.
ME4ME
82
http://www.motorsport.com/f1/news/horne ... ion-issue/
"It does have more power," team boss Horner confirmed to Germany's Auto Motor und Sport, "but it is not evenly distributed.
"There is still a problem with driveability," he added.
Looks more and more like Newey was spot on. He knew(ey) what was comming :mrgreen:
