Scuderia Ferrari SF15-T
TechF1
Re: Scuderia Ferrari SF15-T
Gilles 27 wrote:
Imho they use highspeed camera and need the lights to brighten the dark Spot up.
Yes could be
timbo
timbo
113
F1NAC wrote:Don't they measure ride height aswell?
A red laser is used for ride height measurement.
Ferrari's new tactic; blind the drivers behind so they can't overtake :lol:
[jk offcourse]
interesting, can't remember seeing anybody else use this kind of 'filming'
SRK
SRK
damn beam... :?
So i assume both Ferrari and Mclaren will wait for Melbourne to come up with the short nose?
excellent shots, SRK.
TechF1
Manoah2u wrote:So i assume both Ferrari and Mclaren will wait for Melbourne to come up with the short nose?
Short nose mean a SF15 - T B spec, 'cause they should change many many other parts as well. :P
Juzh
161
There's no such thing as a B car anymore.
TechF1
Yes i agree, i clearly mean we will NOT see any short nose in Melbourne.
Advino116
Advino116
19
Does anyone know why are they running positive camber at the rear? Isn't that the worse thing to to do for corners?
Or is it just the angle?
ME4ME
79
Seems like most teams run positive camber, looking at tyre wear and the stripes visible on worn tyres.
But I guess the camber turns neutral when the car is aerodynamically loaded at low to medium speeds for optimum traction. But that's pure speculating on my side though, could be wrong.
JDC123
JDC123
30
ME4ME wrote:Seems like most teams run positive camber, looking at tyre wear and the stripes visible on worn tyres.
Absolutely not. All teams run negative camber front and rear, the rears are just run at a lower angle than the front, typically 1-2 degrees. U run negative camber so that the outside tyres through a corner have maximum contact patch under sheer with the tarmac. Ideally you would want the inside tyre to have positive camber so that the sheer force pulls the contact patch inwards to the centre line of the car. It's not just as simple as saying negative camber is better. Suspension setup is all about comprimise.
There was a push towards much less rear - in fact nearly nothing or slightly positive in droop on some cars - camber when they were struggling to get tyre life out of the Pirellis - they have a very rounded shoulder and profile at the rear so I assume they were trying to use the inner shoulder down the straights to even wear treadwear out.
2015 Winter testing | Session 3, Day 4 - Circuit de Catalunya, Spain (01.03.2015)
Alexgtt
Alexgtt
Very big front brake ducts on the Ferrari, not sure why?
**Edit - apologies, forgot they're blowing the hub **
Cracking detailed pictures, thanks for posting. =D>
poolboy67
Alexgtt wrote:Very big front brake ducts on the Ferrari, not sure why?
most likely just for reliability during testing. i'm sure they'll bring correct sized ducts for the races.
