Mercedes AMG F1 W06
BlackSwan
BlackSwan
33
Re: Mercedes AMG F1 W06
dren
227
SiLo wrote:Thats a lot bigger than the log exhaust. I'm assuming the power increase from this change must be quite large to offset the loss in free space at the back for Aero.
They are keeping it high to still allow for the undercut airflow.
Honda!
dren
227
That's a large inlet to the intake manifold. It looks like they are still using some sort of integrated cooling within the rear of the chassis for the charge air. It is hard to tell how the intake air gets to the compressor. Does it go between or around the large charge intake?
Honda!
tranquility2k4
tranquility2k4
Is there anything new on that front wing or on the bat wing under the nose? The rear wing has a huge amount of inward curvature to it compared to most teams? Also, is there a new paint job since testing - more black?
frosty125
frosty125
Why does a radiator inlet/exit looks like it is passing through the engine exhaust?
r.t.1.n
r.t.1.n
From AMUS- Australian Grand Prix - Melbourne
240
It's also pushed forward towards the wider part of the car up front.
Very different positioning of components compared to redbull..
aleks_ader
90
That almost guarantee the existence VLIM system on PU114B
dren
227
Yeah, the team stated they were using it somewhere I read. The way that the cover is shaped, I bet it is some sort of screw, log type system rather than the linear axially moving kind.
Honda!
FW17
171
Almost like this piece from Mahle
240
I think their VIR are telescopic in nature. And the box is probably just and air chamber.
comparison nose Merecedes
ParkerArt
ParkerArt
The paint shop should feel ashamed... ASHAMED I tell you!
Even though it would add weight, I hope that the team will waste the few grams worth of paint to make the vanes and winglets on the FW a bit more interesting.
astracrazy
astracrazy
31
i think the addition of a bit more black looks fine
Hail22
144
Thursday 12/03/2015
Looks as if the rear part of the nose cone curves similar to the contours of a spoon
Gilles Villeneuve
