Mclaren MP4-30 Honda
atlantis
atlantis
21
Re: Mclaren MP4-30 Honda
ojlopez
ojlopez
atlantis wrote:https://twitter.com/techF1LES/status/593467742512111616
What a neat piece of engineering.
Nice picture
gavingav1
35
its seems the benefits it brings is packaging the sidepods smaller because the radiator has been removed from the sidepods, but that must be judge against the fact that having the radiator so high in the car must raise the centre of gravity and plumbing must be a nightmare , i wonder if the payoff is worth it at all?
gavingav1 wrote:its seems the benefits it brings is packaging the sidepods smaller because the radiator has been removed from the sidepods, but that must be judge against the fact that having the radiator so high in the car must raise the centre of gravity and plumbing must be a nightmare , i wonder if the payoff is worth it at all?
I read that the closer to the ground you are the warmer the air is, therefore, diminished cooling for the same realestate. Hence a disadvantage of having the same cooling in the side pod would be that it would need to be larger,weight more and cause more drag to get the same cooling.
GoranF1
GoranF1
149
Wrong topic to discuss the livery, guys! Livery belongs either in the team thread, or in the specified mclaren livery topic. I'll move the none-conforming posts later on. In the meanwhile: keep the discussion limited on the technical aspects of the car (except the PU, which also has its own thread).
McLaren livery thread :arrow: http://www.f1technical.net/forum/viewto ... =1&t=21323
Reason: Added link to livery thread
LookBackTime
LookBackTime
472
New rear suspension design?
George-Jung
George-Jung
LookBackTime wrote:New rear suspension design?
https://pbs.twimg.com/media/CEVHq3RWgAAdIHz.jpg:large
What do you think is new?
Egresi Tamás
Egresi Tamás
49
No wishbone winglets
Egresi Tamás
Egresi Tamás
49
CjC
CjC
Supposedly the back end will near enough be totally new....
Just a fan's point of view*
new front wing sin Bahrain ?? NAh I think it's just the angle.
frosty125
frosty125
How can you tell the lower wishbone are not fitted yet....
Rear looks like the same as last race to me so far...
