Lotus E23 Mercedes
trinidefender
trinidefender
317
Re: Lotus E23 Mercedes
itix wrote:
GM7 wrote:This is surely to compare different temperatures, if the temperatures obtained from the left side are good they choose the smaller engine cover.
I actually think that he/she is right rather there being some weirdness going on. It actually looks a lot like one of their old ones from the pre season testing so quite possibly they are doing evaluation.
Unless all the various heat exchangers (radiator, engine oil cooler, ERS coolers etc etc) are exactly the same and split halfway and mirrored on each side then there will be a different transfer of heat from side to side making the air coming our of the back different temps. Therefore it would be useless to do this to compare temps with that idea.
Cardex94
Cardex94
Apparently from what has been out there, Lotus will bring a slightly wider nose to Spain.
jericho
I'm curious what Lotus will bring to Barca. According to themselfs sites they will "raise some eyebrows"...
FrukostScones
162
LOL
Off topic joke, but...
If they finish ahead of the Toro Rosso's, they could change it to "u Mad, Max?"
turbof1 wrote:Off topic joke, but...
lol :lol: :lol:
ltitus8900
ltitus8900
=D> =D> :lol:
Via AMuS
F1NAC
163
kabooom
Damn!
Here's another shot:
That'll cool the PU :lol: . Too much pressure underneath the bodywork?
turbof1 wrote:That'll cool the PU :lol: . Too much pressure inside?
Yup! It is activated via DRS :lol:
You mean Debris-Rear-Scattering?
It really looks like too much pressure built underneath the engine hood and at a point just ripped it to shreds. I know you are joking, but the DRS could actually have played a part there, decreasing pressure on top of the hood.
Say, the RW support pylon attached to the exhaust, isn't that the same solution as the one Toro Rosso uses?
