Mclaren MP4-30 Honda
Re: Mclaren MP4-30 Honda
In Season Test, Tuesday
mikeerfol
68
We want flow viz, we want flow viz! :lol:
No Flow Viz yet i fear..... but some Detail Shots.
f1rules
f1rules
635
is it me or is there something going on with the sidepod, inlet divided into two
EDIT
Nope just shadow area it seems
It looks weird but the outer Part is just a shadow.
f1rules
f1rules
635
:-) yaeh just noticed it, thanks
FW: Gap between Top Cascade & Second Cascade is wider than before:
Flow viz on RW:
[quote="mclaren111"]FW: Gap between Top Cascade & Second Cascade is wider than before:
not sure what you mean?? whish we could draw arrows with this forum.....
There are many new slots on the vertical rear wing supports.
Jef Patat
Jef Patat
66
mclaren111 wrote:FW: Gap between Top Cascade & Second Cascade is wider than before:
http://adn.gpupdate.net/large/265127.jpg
I'm not sure you are correct, looks more like the lowere element being in the shadow of the upper, misleading you.
diffuser wrote:There are many new slots on the vertical rear wing supports.
Are you referring to the 'canards'?
http://somersf1.blogspot.be/2014/07/bit ... 9-new.html
I believe nothing has changed there.
Apologies. Looked at it again very carefully.
You are correct. Nothing new :(
smr
smr
New nose
Mamba
Mamba
Are you not mistaking a sensor bulge for something new?
MAMBA
Sensor bulge, guys.
