This serrated edge doesn't extend as far down as the leading edge. The only thing I can think that these do is to break up the boundry layer on the wing. Usually extra surfaces and bumps just cause the boundry layer to get bigger though. Quite the conundrum.SectorOne wrote:https://pbs.twimg.com/media/CUzm8SuUkAAxtNw.jpg:large
Creating mini-vortexes to keep the airflow attached?SectorOne wrote:https://pbs.twimg.com/media/CUzm8SuUkAAxtNw.jpg:large
yup that's rightMcMrocks wrote:Creating mini-vortexes to keep the airflow attached?SectorOne wrote:https://pbs.twimg.com/media/CUzm8SuUkAAxtNw.jpg:large
Strangely gliders have it also on the under-side of the wing. Almost ripped that zig-zag tape off when polishing a Duo-Discus yesterday. I know it is off topic. But what's the use on the underside?cirrusflyer wrote:Putting this things on the glider wings is well known for atleast two decades. We call it turbolator. It is a zig-zag tape.
They are placed very low in the boundary layer and with is being so low it wouldn't create any useful vortices in the traditional sense.F1NAC wrote:yup that's rightMcMrocks wrote:Creating mini-vortexes to keep the airflow attached?SectorOne wrote:https://pbs.twimg.com/media/CUzm8SuUkAAxtNw.jpg:large
(from Somers)
https://pbs.twimg.com/media/CUwW6E1WoAAdXWT.png
You won't get laminar flow in its actual form with such a heavily cambered wing as in the F1 rear wing.cirrusflyer wrote:Maybe the laminar flow "superaccelerate" over microvorteces without deattaching.
Is it possible that this efect only is in use when DRS is on and the flap is lifted? Is not then camber of upper flap lot less?trinidefender wrote:You won't get laminar flow in its actual form with such a heavily cambered wing as in the F1 rear wing.cirrusflyer wrote:Maybe the laminar flow "superaccelerate" over microvorteces without deattaching.
