AVL Horsepower test
Just for fun. We need more power!!!
Glad you enjoyed it. Of course you need a 'slightly larger' fuel pump from Waterman. Yes GPM does mean gallons per minute! What was that about fuel flow restriction......PlatinumZealot wrote:Now that was a nice video!
In descending order of importance, the changes that have produced the improved power/efficiency are:ringo wrote:I think for this formula, more than turbo charging and the electrical power, the direct injection and fuel pressure technology is the star here. Also the tools used to conduct combustion analysis.
So what is different between my battery assist delivering power at the crankshaft when enable verses the MGUK unit enable??? I have made modifications on the Insight where I can turn the battery assist on when I want and turn off when I want plus how much assist needed by a controlled % increase. I can turn on regenerating braking on when I want and off when I want. From several turbo 400HP per liter engines I built I have seen first hand a decrease in BSFC across the board. Now I want to see on my dyno what happens when you add a electric motor assist in to the equation. Will the BSFC of the ICE only, increase or decrease??? If you have done real life testing in the area please let me know!!!!!Sorry to say, but turbo charging your insight hybrid won't give you any insight into how the MGUK deliver's power.
Also try not to confuse thermal efficiency with fuel mileage. All the engines in F1 can do the same fuel mileage if they need to. The f1 cars achieve fuel mileage by storing energy when it is not needed and then using it when needed.
gruntguru with a ton of respect have you seen this first hand with real life data? No simulation no calculation no assumption, I'm talking your real engine dyno numbers????gruntguru wrote:Adding a motor/generator to the crankshaft won't chnge the BSFC of the engine. It will however allow you to roperate the engine closer to its best BSFC for more of the time - charge the batteries when engine demand is low - discharge the batteries when engine demand is high.
Because of inefficiencies in the electrical storage and retrieval, it will not always be the choice best to use it. For example if the engine demand is such that BSFC is already within 10% of best BSFC, it would probably be less efficient to invoke the storage/retrieval system.
I was just poking some fun PZ, but it does show how remarkable these new PUs are. I wonder if Mercedes were to scratch build a new NA V8 to the 2013 regs, how much power it would produce.PlatinumZealot wrote:Blaze I know you understand that as engineers we cannot just believe rumors without any sort of good reasoning behind them, we have to use the tools and techniques that we know. This why our horsepower numbers were in the 850hp range. With new information from Andy Cowell it is clear that all we have to adjust in our engine calculators is the friction loss and combustion efficiency factors. It appears that our assumptions on these were based on older (outdated?) knowledge in combusiton, tribology and material engineering. Of course Andy Cowell has told us the real number, and we will believe him because he is the most credible source. It doesn't make other members who only follow any rumor they here any better than us, the brave ones who use our engineering skills to take a shot though. In the end it results in a great exchange of knowledge across the site. I have learnt so much new things about engine technology this year alone.Blaze1 wrote:The contributors who suggested 850+ hp power figures in the ' Formula One 1.6l V6 turbo engine formula' thread, were called crazy last year.Even when senior team members mention such figures (last years estimates), they are usually conservative. I recall Marmorini of Ferrari last year speaking of 650hp for the ICE and during the Engine Gurus PC, in which Cowell mentioned efficiencies pushing 40% plus and Rob White half laughing saying it was a bit more than that. The clues were there.
Anyway these PU are incredible, fantastically efficient.
Are you thinking it would be valid to add an electric motor to the crankshaft, measure the total power on a dyno, divide by the fuel flow and call the result a BSFC?pgfpro wrote:gruntguru with a ton of respect have you seen this first hand with real life data? No simulation no calculation no assumption, I'm talking your real engine dyno numbers????gruntguru wrote:Adding a motor/generator to the crankshaft won't chnge the BSFC of the engine. It will however allow you to operate the engine closer to its best BSFC for more of the time - charge the batteries when engine demand is low - discharge the batteries when engine demand is high.
No thats not what I'm saying.gruntguru wrote:Are you thinking it would be valid to add an electric motor to the crankshaft, measure the total power on a dyno, divide by the fuel flow and call the result a BSFC?pgfpro wrote:gruntguru with a ton of respect have you seen this first hand with real life data? No simulation no calculation no assumption, I'm talking your real engine dyno numbers????gruntguru wrote:Adding a motor/generator to the crankshaft won't chnge the BSFC of the engine. It will however allow you to operate the engine closer to its best BSFC for more of the time - charge the batteries when engine demand is low - discharge the batteries when engine demand is high.
Of course that would not be valid. You don't even need a dyno to do the calculation. If your electric motor has the same output as the ICE, the "BSFC" will be half that of the ICE alone. Five times the output of the ICE and the "BSFC" will be one sixth . . . . and so on.
