Williams FW38 Mercedes
tomazy
tomazy
230
Re: Williams FW38 Mercedes
The car is missing rear brake ducts, or at least all the winglets on it and rear pull rod attaches way forward to the chasis :wtf:
EDIT: there is also no sign of the turning vanes under the nose. I can't wait for the pictures tomorrow to see if the cars has them or not (the same with the rear brake winglets).
LookBackTime
LookBackTime
472
Did they close the exit above the gearbox?
Right now i can't say for sure...
bill shoe
bill shoe
151
PhillipM wrote:I didn't say the front, I said the rear.
Apologies, I was referring to this report:
F1 Analisi Tecnica - WILLIAMS FW38: l'analisi tecnica
and a couple other comments I saw elsewhere. I should have been more specific.
Voting is allowed again. However, there will be removal of some votes later on.
LookBackTime
LookBackTime
472
LookBackTime
LookBackTime
472
LookBackTime
LookBackTime
472
LookBackTime
LookBackTime
472
Stalker1
Stalker1
16
bill shoe wrote:On the front suspension, I don't see the lowered wishbones referred to by multiple people. The droop/anhedral angle of the front suspension appears the same. The upper wishbones appear to be at almost exactly the same height as last year. The lower wishbones look very slightly higher than last year, thus the upper and lower wishbones may be tad closer together now. Overall, I would say the amount of side-scrub per unit of vertical travel is probably quite similar to last year's car. If anyone has a clear opinion about anti-dive from the pics so far then you're doing better than me.
Unfortunately, I have to agree. I am impressed with their efforts in increasing over-all aerodynamic efficiency of the car, especially with developments in the rear-end of the car. However, I do not see how these developments are going to help in solving the issues with tyres not achieving the working temperature , somewhat high tyre wear and low-speed perfomance. I believe they know what they do and they have choosen the right development path. Just little unimpressed with seeing no considerable changes in the suspension layout.
LookBackTime
LookBackTime
472
LookBackTime
LookBackTime
472
The front wing is different from the launch pictures :)
F1NAC
173
They have slightly different positioned wastegate pipes than Merc
LookBackTime wrote:The front wing is different from the launch pictures :)
Final 2015 model i think, the one on the launch was an older version.
The gearbox hot air exit is indeed closed and an "extreme" looking diffuser are the new bits.
