Mercedes AMG F1 W08 EQ Power +
GPR-A duplicate2
64
Re: Mercedes AMG F1 W08 EQ Power +
Bargeboard details...
Via AMuS
ClarkBT11
Is that a new to the left of the bargeboard?
ClarkBT11
GPR-A duplicate2
64
Diffuser...
Mattchu
59
Seems pretty tough the Mercedes, that`s quite a whack! The back seemed to snap round pretty quick...
roon
roon
412
Mattchu wrote:Seems pretty tough the Mercedes...
The Merc, or the Pirellis? ;)
diego.liv
diego.liv
F1analisitecnica.com usually is spot on with their technical analysis
Merc is trying to make the double T-wing to flex at a maximum point in order to create more rear downforce, creating a faster air flow that hits the rearwing.
On a sidenote, other italians at the track/commenting online were saying that the double-T was flexing "a lot"
Shakeman
33
diego.liv wrote:F1analisitecnica.com usually is spot on with their technical analysis
Surely if it's obviously a flexi-wing it'll be banned in no time.
mikhak
mikhak
How would flexing the wing help? Generally speaking there are two reasons to flex in F1, (1) to extend the geometry outside of the legality boxes e.g. front wing flexes closer to the ground, (2) flexing to reduce drag e.g. front wing flap reducing angle with speed.
You can put the T-wing more or less where you want in terms of height so i don't see a benefit of flexing downwards. What about flexing rearwards to get closer to the rear wing, why would this increase downforce. If anything it would unload the rear wing.
The only way i see flexing to benefit is to reduce the angle of attack of the the element itself so you can have an aggressive aoa for downforce generation but lose the drag at higher speed.
kooleracer
kooleracer
https://it.motorsport.com/f1/news/ferra ... ff-878379/
According to the italian version of motorsport. Mercedes are due to release a update worth at least a full second.
Irvine:"If you don't have a good car you can't win it, unless you are Michael or Senna. Lots of guys won in Adrian Newey's cars, big deal. Adrian is the real genius out there, there is Senna, there is Michael and there is Newey.They were the three great talents."
dans79
267
kooleracer wrote:https://it.motorsport.com/f1/news/ferra ... ff-878379/
Jesup, that was painful to read, it's so badly written that translators can do anything with it.
202 105 104 9 9 7
F1Krof
95
Don't read too much into it. The usual Italian Media trying to scare Ferrari into working hard. That's only speculation, however we all know that the second test is for performance aquisition. Mercedes, Ferrari eveyone will bring updates.
Wroom wroom
diego.liv
diego.liv
mikhak wrote:How would flexing the wing help? Generally speaking there are two reasons to flex in F1, (1) to extend the geometry outside of the legality boxes e.g. front wing flexes closer to the ground, (2) flexing to reduce drag e.g. front wing flap reducing angle with speed.
IF the article is spot on, based on what i recall about physics it could be this way
When you have two surfaces not parallel but inclined, even slightly, they will act as a funnel, compressing the air: the exit speed of the airflow is higher than airflow speed at the opening.
When the car reaches a certain speed, the double-T flexes enough to become a funnel (or maybe, the two Ts are already not parallel) and direct the flow passing through it, in the direction of the rear wing: wheter it is under, on, above the wing it's another matter for i know.
But the point is that the turbulent air coming through the double-T becomes cleaner/less turbulent and is directed where you want it
