2017 Tyres revealed
F1NAC
173
Re: 2017 Tyres revealed
roon wrote:
10 Mar 2017, 01:24
Is there a term for the circumferential bead of rubber that builds up on the tire during cornering?
https://s9.postimg.org/o90tjip7j/image.jpg
https://s9.postimg.org/ub8ga0dnj/image.jpg
Graining? looks like that.
n4rf
n4rf
34
F1NAC wrote:
07 Apr 2017, 22:18
roon wrote:
10 Mar 2017, 01:24
I would call it blistering or forming of blisters. It is locally too hot rubber that results in the surface of the tire bursting open (blistering). So it is not a bead of rubber. But this dark strip is characteristic for this phenomenon.
FrukostScones
AMuS: Pirelli tricked into raising tyre pressures by being handed incorrect (too high) down force values coming always from two certain teams.
http://www.auto-motor-und-sport.de/form ... 34439.html
https://translate.google.com/translate? ... t=&act=url
BanMeToo
BanMeToo
F1NAC
173
Ultrasoft for Spa!
BanMeToo
BanMeToo
No more hard tires for 2017.
Does it make sense to bring ultra softs to Italy?
SameSame
SameSame
How can Spa and Monaco have the same tyre allocation #-o Did Pirelli not say they had softer back-up compounds available?
ENGINE TUNER
ENGINE TUNER
25
godlameroso wrote:
22 Jun 2017, 18:30
Way more sense than bringing them for Spa
ENGINE TUNER
ENGINE TUNER
25
SameSame wrote:
22 Jun 2017, 20:23
I think the back ups were not softer but had more thermal deg built in, not %100 sure though
FPV GTHO
FPV GTHO
I thought the backups were harder, invade development significantly ramped up.
wuzak
wuzak
532
ENGINE TUNER wrote:
22 Jun 2017, 20:28
SameSame wrote:
22 Jun 2017, 20:23
I think you are correct. The backup compounds had more degradation designed in.
DaveW
DaveW
239
Might this be something to do with F1's problems? The image is an animated GIF, better viewed at 200% on my computer, recorded at Spa Q1, I think. The instability, affecting the whole structure, was probably caused by kerbs, but tyres were clear of kerbs in the recording.
Your comments, please....
FW17
184
New tyres are good but it is quiet sad that the current engines with almost a 1000 hp could not crack the 350 kph mark and nowhere close to the all time speed record of 372kph
The current tyres now seem to be limited to just 3 specs in most races with medium and hard not going to be seen again
I think for 2018 Pirelli can offer the 3 softest tyres in 2 sizes to have a range of 6 tyres. 3 types, ultra softs, supersofts and softs in 2017 sizes (305 front 405 rear) and 3 types, ultra softs, supersofts and softs in 2016 sizes (245 front 325 rear)
If they did that will the chassis be able to handle 2 different tyre sizes during the race?
henry
324
DaveW wrote:
03 Sep 2017, 10:37
That's certainly very dramatic footage but it's hard to know how to compare that to any previous era. We have had, in the past, occasional slo-mos of transverse vibrations in slow corners and the notorious Michelin standing waves from Indy.
I wonder if these vibrations were so pronounced because once established there was nothing to attenuate them. The transverse vibrations seen in cornering go away when direction is changed but here the input power to the tyres is pretty much constant as soon as the driver demands WOT.
Incidentally the transverse vibrations were to be seen in the safety car's rear tyres as it traversed the chicanes in the rain during the reconnaissance laps before qualification.
