More or less that's what they usually weighbill shoe wrote:Chassis diagram appears to show half of a monocoque that totals ~ 40 lbs. So is the complete monocoque ~ 80 lbs?
80lbs is 36kg. That seems on the low side to me. That diagram is just showing where the aluminium honeycomb is going to be positioned for FEA and manufacture. It excludes the weight of suspension and other mounting inserts, rohacell core, carbon weave and resin (sandwiched together in pre-preg), which depending on the number of layers will add significant weight. 70-80kg total would be more like it. The monocoque weight has been increasing in recent years due to improved penetration protection around the suspension arms.ScrewCaptain27 wrote: ↑Tue Aug 15, 2017 10:13 amMore or less that's what they usually weighbill shoe wrote:Chassis diagram appears to show half of a monocoque that totals ~ 40 lbs. So is the complete monocoque ~ 80 lbs?
Thanks, OK so the 80 lbs or 36 kgs is simply the weight of the aluminum honeycomb, not the weight of the overall monocoque. The overall weight would be ~ 70 kg or slightly more due to increased penetration protection, etc.jjn9128 wrote: ↑Tue Aug 15, 2017 11:11 am80lbs is 36kg. That seems on the low side to me. That diagram is just showing where the aluminium honeycomb is going to be positioned for FEA and manufacture. It excludes the weight of suspension and other mounting inserts, rohacell core, carbon weave and resin (sandwiched together in pre-preg), which depending on the number of layers will add significant weight. 70-80kg total would be more like it. The monocoque weight has been increasing in recent years due to improved penetration protection around the suspension arms.ScrewCaptain27 wrote: ↑Tue Aug 15, 2017 10:13 amMore or less that's what they usually weighbill shoe wrote:Chassis diagram appears to show half of a monocoque that totals ~ 40 lbs. So is the complete monocoque ~ 80 lbs?
EDIT: a quick google shows scarbs quoted 70kg back on 2006
I believe so. I also found that the Dallara DW12 monocoque is 81kg (or 179lbs) so close to 70kg for F1 seams reasonable.
dero wrote: ↑Sun Oct 04, 2015 6:15 pmtorrent pretty please?![]()
http://www.cutestpage.com/pictures/Pretty_Please.jpg
