McLaren MCL33
JPBD1990
45
Re: McLaren MCL33
tomazy wrote:
25 Feb 2018, 16:59
It is an optical illusion. That is only the curve where the sidepods meet the floore nothing more.
So it is! The orange is simply reflecting on the black floor making it seem like a feature. Should have looked harder, but I was convinced! Thanks for the reply
Bisonas
Re: McLaren MCL33
https://formulaone21.wordpress.com/2018 ... -analysis/
According to this analysis, which i discovered today morning (i missed it until now) the larger Roll hoop inlets we are seeing this year are for making possible "to raise part of the cooling system, to permit narrower sidepods for greater rear end performance"
This will result to Higher CoG but better rear end performance.
Mclaren is staying loyal to its philosophy to Keeping most of the cooling parts as low as possible for better CoG thus relying mostly to side air inlets for coolling and not on the roll hoop inlet.
Also according to this analysis, MCL33 has a bigger floor thus an increased wheelbase. Maybe not as long as Mercedes or the new Ferrari, but its longer than last year for sure.
Avocado
Re: McLaren MCL33
roon
412
Re: McLaren MCL33
tranquility2k4 wrote:
25 Feb 2018, 11:43
How on earth do McLaren have such a small engine roll hoop inlet compared with Renault and Red Bull, and yet their sidepods are also tiny? They have done a great job of packaging the PU and one would imagine this first iteration is also conservative and may get tightened up even more once they know the cooling works. Dare I say, could this be a sign of McLaren bringing back cutting edge innovative technology, as they used to have regularly?
Maybe they've gone full microtube.
Re: McLaren MCL33
roon wrote:
25 Feb 2018, 23:38
25 Feb 2018, 11:43
You can see in the radiator shots that the side pod bodywork is a bit wider than the radiators would require, looks like they're leaving a bit of a void within the bodywork.
Joseki
Re: McLaren MCL33
sirexilon
Re: McLaren MCL33
I've seen this pic in Twitter, could this be correct?
The car seems really short here.
https://pbs.twimg.com/media/DWuUsflW4AA7azN.jpg
Life long F1 fan. Always learning about all the tech around my favorite sport.
http://www.facebook.com/f1myway
wuzak
445
Re: McLaren MCL33
sirexilon wrote:
26 Feb 2018, 05:40
Look at the size of the wheels and the width of the rear wing. It doesn't seem proportionally correct.
Squid
Re: McLaren MCL33
There's absolutely no way to compare two different photos from two different cars taken by two different studios at two different angles wiht two different lenses.
Bisonas
Re: McLaren MCL33
Ferrari will probably have a slightly longer wheelbase this year compared to Mclaren , but the difference in the pic is huge. No way this pic is representative.
Re: McLaren MCL33
Cute little lower T-Wing
f1rules
569
Re: McLaren MCL33
dont know what is going on around the driveshat but the sun seem to outline a curve
Avocado
Re: McLaren MCL33
Re: McLaren MCL33
There was a Halo Fairing mounted when Fernando lost that Wheel.
