Mercedes AMG F1 W09 EQ Power+
ScrewCaptain27
577
Re: Mercedes AMG F1 W09 EQ Power+
Via AMuS
- Serj Tankian
New front wing endplate
This is the old one
Via @LuisFeF1
New rear wing.
FW
OO7
OO7
171
bonjon1979 wrote:
01 Mar 2018, 11:49
RZS10 wrote:
01 Mar 2018, 03:31
So assuming that the scale is 10cm between each line and that the yellow lines mark the axles ...
https://i.imgur.com/OpXGL2w.png
The wheelbase would be around 386-388 cm which would be way longer than the old calculation.
I used the ruler tool in PS to measure that stuff
I tried to confirm the assumption of 10cm by measuring the wheel which ended up being 62.xxx pixels which divided by 0.9 is roughly 68cm
I also tried to confirm the assumption that the yellow lines mark the axles by drawing squares around the edges of the front and then the rear tyres which then allowed me to find the middle of those, thus marking the axles.
https://i.imgur.com/eXPgOCY.png
Ofc the pic is wayyyyy too pixelated/low res to take any of this seriously
Stirling work! This is what we're after.
How come I didn't get any praise for my work bonjon!? :(
OO7
OO7
171
MtthsMlw wrote:
01 Mar 2018, 11:29
The front of the 'cape' is different or what is going on there?
https://www2.pic-upload.de/img/34922997 ... 102651.jpg
Good spot MtthsMlw.
DVB
Looks like a massive bargeboard! They are trying to get some air speeded up!
Everybody is a Ferrari fan.
A Go Pro is filming the new FW.
djones
djones
If they are filming it, then presumably it flexes?
zibby43
zibby43
A few more shots of the front wing:
[media]https://twitter.com/AlbertFabrega/statu ... 2459214848[/media]
godsire
godsire
They have also increased the number of endplate elements (swept-back black arches) from 6 to 7:
Before:
After
OO7
OO7
171
godsire wrote:
01 Mar 2018, 13:21
Before:
https://image.ibb.co/b79JAx/before.png
After
https://image.ibb.co/eCjqOH/after.png
There are still only 6 godsire. 2 & 3 at the bottom aren't split, they're a single piece.
DVB
djones wrote:
01 Mar 2018, 13:04
No, they aren't filming the flex. Flex is easily tested in a wind tunnel.
The front wing flaps have been reduced in number and length. At the Y250 location, the flaps no longer appear to be involved very much. This suggests a weakened Y250 vortex is being generated.
This accords with my suspicion that Mercedes have moved away from the use of an increasingly powerful Y250 vortex and manipulating it, and are using the cape to set up a strong vortex that is directed and strengthened by the turning vanes/barge boards. The Y250 vortex that is created is just then used to guide tyre wake, as originally intended, with the cape vortex being used for downforce production or floor "sealing".
garyjpaterson
DVB wrote:
01 Mar 2018, 14:04
djones wrote:
01 Mar 2018, 13:04
Really, on a 60% model, which is presumably constructed with different methods and materials?
djones
djones
DVB wrote:
01 Mar 2018, 14:04
djones wrote:
01 Mar 2018, 13:04
Is it though?
I mean yeah to a certain extent, but they are not allowed to use full size models these days. And also the wind tunnel cannot do 150+ MPH?
