Scuderia Ferrari SF71H
Kormidlo
Re: Scuderia Ferrari SF71H
Post by Kormidlo » Tue Mar 13, 2018 4:35 pm
Just_a_fan wrote:
Tue Mar 13, 2018 4:34 pm
Kormidlo wrote:
Tue Mar 13, 2018 4:31 pm
Can we take this as something like car performance indication, or, do you think other cars from top 3 teams are able to do that too???
In one of the interviews during testing (with Costa I think) there was mention that Hamilton had been flat through there too. Likely that the top three (or more) are all able to do it this season.
Ok thank you, I will find that interview...
CriXus
84
Post by CriXus » Tue Mar 13, 2018 5:00 pm
Seb was not flat out through turn 9. There was a slight lift.
"Without music, life would be an error!!!" - Friedrich Nietzsche
Kormidlo
Post by Kormidlo » Tue Mar 13, 2018 7:46 pm
Ok, I can see it (hear it) now clearly that he lifted a bit... I found that interview with Mercedes drivers and both sayed that they was flat out. Hamilton sayed that he now experiencing most g-forces in his life in F1 car ever :shock: :shock: :shock:
So, why Seb lifted a bit, when he was on the hot lap? Do you think, he did it on purpose to hide speed? Or Ferrari can not go flat out trought T9???
Post by Just_a_fan » Tue Mar 13, 2018 8:54 pm
One thing that strikes me in this image is how much volume in the car is taken up by the driver. With the cockpit side pads removed, we can see the size of the tub - something that's normally disguised by the cockpit sides and the driver's helmet.
The image is a really good demonstration of how small F1 cars really are. Sure, they're long and quite wide across the axles but the shrink-fit bodywork of modern cars is really shown here. Whenever I've stood next to a Formula 1 car I'm always struck by how small they really are. Same goes for LMP1 cars when you see them overtaking a Porsche 911. The 911 looks big next the LMP1 and we know the 911 isn't huge in reality.
Anyway, this is slightly offtopic but I wanted to point out that the image is useful for things other than just looking at the Ferrari. 8)
Turbo says "Dumpster sounds so much more classy. It's the diamond of the cesspools."
Kalsi
27
Post by Kalsi » Sun Mar 18, 2018 11:55 pm
Well.... This really depends on the speed you enter the corner.... If vettel enters faster than hamilton... He needs to lift 😅
Post by Sevach » Mon Mar 19, 2018 6:54 pm
SF 70H Abu Dhabi vs SF 71H test spec.
A few extra deflectors, redimensioned "L" elements.
designf1
75
Post by designf1 » Tue Mar 20, 2018 8:20 am
Post by Sevach » Tue Mar 20, 2018 8:14 pm
till.a.fischer
Post by till.a.fischer » Wed Mar 21, 2018 12:35 pm
Auto Motor und Sport reporting about the Smoking Ferraris:
Meanwhile, the mystery of the smoking Ferrari engines is clarified. Obviously there was a lot of bearings in the turbocharger with too large tolerances. As a result, oil was blown into the engine through the compressor and burned. That's why the phenomenon was seen only in Ferrari and Sauber. In the turbocharger for HaasF1 a different batch of bearings should have been installed.
f1316
127
Post by f1316 » Wed Mar 21, 2018 1:41 pm
https://www.motorsport.com/f1/news/ferr ... B_r_r43O3W
Just on the last point "One issue of concern to the team, however, is the fact that the increased weight of 2018 cars, allied to more full-throttle time over a race lap this year, will lead to an increase in fuel consumption – something that could hold it back at tracks like Melbourne."
Is it possible that the bearings 'with too large tolerances' mentioned above were impacting fuel consumption? I guess they weren't allowed to burn oil as fuel, but it doesn't sound as if it would be helpful to do what's described. Could also explain the relatively good performance of the Haas?
noname
Post by noname » Wed Mar 21, 2018 1:43 pm
I am not buying this. I suppose if the clearances were that much off turbo would not last long.
And for sure they would catch this on a dyno. Each turbo and each PU is going through sign-off test before making its way into the car.
I doubt there is anybody in Maranello willing to report serious quality offence to Marchione.
roon
350
Post by roon » Wed Mar 21, 2018 7:28 pm
scarbs wrote:
Fri Mar 09, 2018 6:22 pm
Interesting feature. Seems like something the other teams could easily adopt.
Moose
126
Post by Moose » Wed Mar 21, 2018 10:12 pm
Yes - and it's something that's been adopted by many teams in the past, if they're not doing it already, it's likely not of benefit to them.
JPBD1990
29
Post by JPBD1990 » Thu Mar 22, 2018 1:55 am
edxferrari
Post by edxferrari » Thu Mar 22, 2018 2:26 am
