McLaren MCL33
604gtir
Re: McLaren MCL33
Post by 604gtir » Tue Mar 13, 2018 10:38 pm
BrunoH wrote:
Tue Mar 13, 2018 9:50 pm
lack of top speed even with DRS....
also i have the suspicion that they did not use the S-duct to reduce further drag
so you have factual hard data regarding every teams test plans?
you have no idea where drivers are lifting, which drivers are lifting, how much power people are running, what people are testing but you can come up with a conclusions based on 2 pieces of information. seems credible.
Xero
30
Re: McLaren MCL33
Post by Xero » Tue Mar 13, 2018 10:56 pm
Lack of speed due to tuning the PU down, as per Renault's recommendations. No point running the s-duct in that configuration. Also allows them to evaluate the base car with less variables. Furthermore, if McLaren's upgrade is as big as expected for Aus, then that whole section of the car could be totally different. All educated guesses I know, but let's not jump to conclusions, especially with the tired and old draggy aero argument.
radosav
42
Re: McLaren MCL33
Post by radosav » Tue Mar 13, 2018 11:53 pm
Maybe they simulated downforce levels that they expect from aus aero update.
makecry
37
Re: McLaren MCL33
Post by makecry » Wed Mar 14, 2018 12:19 am
Yeah you can't "Simulate" downforce without an actual hardware. It's not a video game.
radosav
42
Re: McLaren MCL33
Post by radosav » Wed Mar 14, 2018 12:28 am
I mean they used draggy downforce to reach levels of not draggy downforce from aus aero update to see how suspension behaves through corners etc...
Maybe..
ollandos
Re: McLaren MCL33
Post by ollandos » Wed Mar 14, 2018 1:15 am
the highest top speed for mclaren in test it was 325.x from alonso ...the day with swap with stoffel and drive for the last 2-3 hours...last year with honda it was 315.x
DiogoBrand
68
Re: McLaren MCL33
Post by DiogoBrand » Wed Mar 14, 2018 2:33 am
I knew that Ferrari had taken inspiration from McLaren's slotted nose pillars, but only now I saw that they also have slotted elements on their front wing, just like McLaren. So since Honda joined, we saw their s-duct, wing slots and nose pillars copied, and also I think they were the first to have the fins on the outside of the rear wing endplates (correct me if I'm wrong).
All of that to me indicates that their aero department is on the right direction, perhaps with proper power we could see some good results.
Jef Patat
89
Re: McLaren MCL33
Post by Jef Patat » Wed Mar 14, 2018 9:03 am
Please... before rambling on at least try to understand what parts are for. An S-duct reduces drag by energizing the flow around the step in the nose. This is a good explanation. Be sure to check all three pages:
http://en.f1i.com/magazine/8277-tech-an ... -duct.html
toraabe
Re: McLaren MCL33
Post by toraabe » Wed Mar 14, 2018 9:07 am
More rake, lower topspeed
aral
Re: McLaren MCL33
Post by aral » Wed Mar 14, 2018 12:04 pm
General comments and disputes about the effects of rake are not car specific and should be discussed on the aero forum.
Egresi Tamás
30
Re: McLaren MCL33
Post by Egresi Tamás » Wed Mar 14, 2018 7:53 pm
Jackles-UK
16
Re: McLaren MCL33
Post by Jackles-UK » Thu Mar 15, 2018 12:21 am
Interesting to see the hot air exits on the Merc engined cars appear far smaller than their competitors despite putting out the highest power.
Any ideas why the McLaren ones are situated so much higher up than all the others (they're actually level with the exhaust tip)? Given the issues with cooling around this area in testing I wouldn't be surprised to see this area of the engine cover altered for Melbourne.
DiogoBrand
68
Re: McLaren MCL33
Post by DiogoBrand » Thu Mar 15, 2018 12:51 am
I would guess that they're that high to allow more air to flow underneath the exits and on top of the diffuser.
216
Re: McLaren MCL33
Post by ringo » Thu Mar 15, 2018 5:02 am
well there you go, less cooling is as a result of the power going to the crankshaft and not as rejected heat.
efficiency equals power in this formula.
Can we say if this car failed to meet targets at this stage?
Would be interesting to see how far off redbull it is.
f1rules
117
Re: McLaren MCL33
Post by f1rules » Thu Mar 15, 2018 7:29 am
a very nice angle here that shows exactly what mclaren gain from their different rear suspension, beside an undisturbed area around the brake-ducts and all the winglets surrounding it, they get a complete clean flow near the floor around the sidepods into the central diffuser, worth noticing also, mclaren with their diffuser has the lowest "cut" of all teams in the central spoon shape to allow air from the top to pass through
going through all the test pics so far, with flowvis and everything, they really seem extraordinary comitted to sealing the diffuser and extracting the most of it, add to that, that they are able to run the fw visibly closer to the ground during load, then other teams, i really am quiet optimistic about this car even it havent shown a lot of pace so far
And the sealing
the rear incl central part, disregard the numbers
lastly they moved the lower arms so close together they basicly work as one big flow conditioner, especially the front pickup point has been moved back to achive this but also for not to disturb the airflow further forward, i think
Compared to renault where the suspension arm pickup point is more forward
My main worry is if the agressive mclaren rear suspension is mechanically good enough, or to big a compromise has been made to accomodate aero
