Mercedes AMG F1 W09 EQ Power+
shady
shady
Re: Mercedes AMG F1 W09 EQ Power+
If I was a betting man, I would think that 'diffuser strakes' will be added to the cape before the end of the season. I expected them last season, but there may have been no need to introduce. Similar to the way the cooling vents were added to the shark fin last season.
jh199
32
Does anyone know why Mercedes has a purple light beneath the roll hoop camera? I've seen the green, yellow and red lights but never purple. Does it indicate a sort of pit out mode for the car?
(And please remove this post if it's not technical enough, maybe it belongs in the team thread)
Right-click and open in a new tab for full resolution
roon
roon
412
Morteza wrote:
29 Apr 2018, 00:41
https://i.imgur.com/0zcbI5g.jpg
What's compliant for roll in this arrangement? What's the mass/body above and integral to the steering rack?
Edit- According to motorsport.com, the roll bar is a torsion spring installed only on the driver's right side rocker. Apparent when you see that only one is filled with extra componentry and a locking key.
Maritimer
Maritimer
19
shady wrote:
27 Apr 2018, 22:16
Would stakes in the cape be legal? I feel like they would see it as a diffuser then
shady
shady
Maritimer wrote:
02 May 2018, 04:54
I am not sure.. but theres a cape there, and other teams have vanes... so, Im not sure what in the body work rules would prohibit it. They already have slits on the outer most edges on the trailing edge of the cape.. just a hunch.
Maritimer wrote:
02 May 2018, 04:54
Why would they? Outside of that, they can think it is a diffuser, but doesn't change any fact that attached surfaces all fit according for the rulebook. That wouldn't make sense because then you are challenging the whole rule book based on the definition of words.
The rules define where you can put bodywork. They don't define what that bodywork does or is called. If the cape and any strakes fit within the allowed box for bodywork then it's legal.
Maritimer
Maritimer
19
shady wrote:
02 May 2018, 19:31
Maritimer wrote:
02 May 2018, 04:54
I don't know either, I was under the impression having a blatant diffuser behind your front wing sitting in the Y250 neutral zone would be frowned upon. The way it sits right now you can argue it merely functions like the separate vanes each other team use aside from Williams, guiding air rather than generating its own discrete downforce.
bill shoe
bill shoe
151
ImageWhy does the pitot-tube fin have 3 different pitot tubes?
Guesses-
1. different readings from different tubes provide estimate of turbulence.
2. if one pitot gets clogged with a spec of dirt, the other two pitots that still agree can be identified as correct and so good data continues.
I don't see anything new yet.
Source
f1316
88
I don’t know: looks like a pretty extreme low-drag nose/front wing solution :wink: :lol:
F1Krof
96
Don't expect too much really. Knowing from previous seasons, they don't normally bring any big updates, just refinement of what they already have.
Wroom wroom
@ScarbsTech
New Sauber-like fins on the joint between the top wishbone and upright
Also some close-up shots
Photos via AMuS
