Scuderia Ferrari SF71H
Xwang
Xwang
29
Re: Scuderia Ferrari SF71H
What if Ferrari return to use a mirror not hanged to the halo but with the winglet (something very badly drawn in this image by myself):
Same connection to the tube as previous races, but winglet upside.
Is it forbidden?
siskue2005
70
Xwang wrote:
12 May 2018, 18:14
https://postimages.org/
Is it forbidden?
then the drivers wont be able to see anything
Xwang
Xwang
29
siskue2005 wrote:
12 May 2018, 18:29
Xwang wrote:
12 May 2018, 18:14
Is it forbidden?
How a winglet mounted upon the mirror can reduce the visibility of the pilot (excluded some portion of sky or standing)?
From his point of view both the proposed winglet and the supporting "struct" (which is the mirror one but longer) should be pretty high and do not reduce visibility. Do you agree?
[EDIT] I have found that a so designed winglet could be in breach of 3.5.2 if not considered a mirror mounting ans in the case of this lower mounted mirror it seems pretty impossible to justify the winglet from a structural point of view, but maybe a solution like this
in which mirror and winglet have two different mountings and are connected to reduce mirror vibrations (and to gain an aero advantage as a legal secondary benefit being the winglet not designed only for aero reason but a different form of mirror mounting) could be considered legal and obtain the same effect of the Spain version.
Zynerji
112
Sevach wrote:
12 May 2018, 17:58
It's really weird where the FIA chooses to draw the line... Red Bull has a car with twin mirror stalks, obviously shaped to turn the air around and not peep has been heard about it.
I guess the halo is sacred...
I would counter protest every aero beneficial mirror stalk on the grid immediately.
...and this belief that in an aero formula that you cannot make anything that benefits aero is uttetly retarded.
Cuky
65
Xwang wrote:
12 May 2018, 18:14
Is it forbidden?
FIA has stated in it clarification that mirrors can't be mounted to the chassis and to the HALO at the same time. Either one is OK, but not both.
Mirrors cannot be mounted both on the halo and the chassis, because such an arrangement would make it harder to remove the halo.
Quote is taken from this article
https://www.autosport.com/f1/news/13557 ... lo-mirrors
Zynerji
112
Mirrors have never been exactly stable. Refusing a 2 attachment mount seems rather counter intuitive from a safety and race awareness standpoint.
Xwang
Xwang
29
Cuky wrote:
12 May 2018, 18:53
Xwang wrote:
12 May 2018, 18:14
Is it forbidden?
What I was proposing was to return to a chassis connected mirror with no Halo connection (I've drawn a yellow X on the image). The trick is to design the winglet as a mirror mounting (see above my EDITed post)
RZS10
359
I doubt that any such solution would be legal, otherwise we would have seen them long ago
I guess the FIA did not specify any 'box' or dimensions for the halo mirror mounts which lead to the (very optimistic) Ferrari solution
What i wonder is, will Ferrari try to make a mockery of today's decision by doing something like this? :lol:
Zynerji wrote:
12 May 2018, 18:38
Sevach wrote:
12 May 2018, 17:58
It would also knock Ferrari's "hollow" mirror design out too. I'd bet that Ferrari might well lose out on that sort of "damn them all" approach. The fact they are trying clever things in this area suggests that it's required to maximise their overall concept. I bet RedBull or Mercedes would lose less from a "everyone must run a single, simple mirror stalk" mandate.
I don't think FIA will allow any more winglets to appear above or bellow mirrors themselves again. The only way they can force this is by banning bodywork up and down from mirrors in some extent - 5-10mm perhaps.
roon
roon
412
Sevach wrote:
12 May 2018, 17:58
And let's not forget Force India's solution. Purely structural, no doubt.
The lesson being...
Connecting the mirrors to the sidepod crash stucture cover: OK.
Connecting the mirrors to the halo structure cover: not OK.
roon wrote:
12 May 2018, 20:44
The lessons being...
Obstructing the driver's vision with connections beneath the mirror: OK.
Improving the driver's vision with connections above the mirror: not OK.
Wrong. Connecting the mirrors to the halo is ok. What's not ok is sticking a big aero winglet on the mounting stalk.
Cuky
65
Xwang wrote:
12 May 2018, 19:03
Cuky wrote:
12 May 2018, 18:53
Xwang wrote:
12 May 2018, 18:14
Is it forbidden?
I have to apologize then, as I have misunderstood your original post
roon
roon
412
Just_a_fan wrote:
12 May 2018, 20:53
Further lessons, this one a bit more confusing:
Sticking a big aero winglet on the mounting stalk: not OK.
Sticking a big aero winglet on the mounting stalk: OK.
They used the updated suspension in Qualifying on both cars.
