djones
djones
21
Re: Ferrari Power Unit
Yes, I meant the crazy start-up smoke :)
LM10
LM10
105
Alright then. :) I don't know, if it still was smoking at start-up. But from a technical point of view: Why would it stop smoking at start-up, but keep on smoking as usual on track? This means that only the heavy smoking after starting the engine would be related to the oil burning via turbo which Ferrari was accused of, but not the quite visible smoking on track. How so?
djones
djones
21
Totally guessing. But in my head I thought maybe the turbo leaked oil slowly on purpose. And a small pool builds which then means it smokes like hell on start up.
Big Tea
LM10 wrote:
Thu Jun 07, 2018 6:06 pm
Maybe internal components have to reach a temp where a chemical change occurs or particle Sublimation?
Or the other end and particles condense while its cooler and 'burn' incorrectly?
I am very much in favour of filtered water. Preferably passed through a brewery
gruntguru
gruntguru
458
The whole point of deliberate oil-burning would be to make power. To get the maximum power benefit would require complete combustion of the oil. "Smoke" is an aerosol consisting of unburned solid or liquid particles. You can work the rest out.
Complete combustion of a heavy hydrocarbon would be more easily accomplished in a hot engine. Cold engine equals more smoke. Not to say there is/was not an issue with accumulated oil residue on startup - just saying engine temperature is another factor.
RZS10
153
Any information about what went wrong with the spanking new engine in Grosjean's car?
amho
RZS10 wrote:
Sun Jun 10, 2018 12:40 am
Grosjean asked a wierd quastion: " engine failure or dumping oil" , what does he meant by "dumping oil" ? how can an engine dump oil without any engine failure?!!!
There is no Might or Power except with Allah.
amho
Ferrari and Mercedes both are accused of burning oil. Fuel and oil both are hydrocarbon, my question is that why Fia does not perform exuast gas analysis to count burn/unburn hydrocarbons at wot to find out temporary exessive oil burning?
djones
djones
21
I don't know why the Ferrari fans always say the oil burning issue is them and Mercedes.
At no point has anybody officially challenged Mercedes. Ferrari however were found with a second oil tank for a start.
Mercedes also highlighted things like using the turbo oil to the FIA.
djones
djones
21
Was the Haas engine that blew up the new spec? If so, a bit worrying for Ferrari.
djones wrote:
Sun Jun 10, 2018 3:39 pm
Yes new spec. We don't know yet if it was an issue with the spec 2 engine in general or something Haas did 'wrong'.
Brake Horse Power
Brake Horse Power
Dutch television reported a faulty assembly by Haas personnel. They also said the engine was still okay..
Despite the big smoke show, you could see the engine still running.
Haas is creating a history of messing up procedure and installation.
Oil overfill, blew it out through the turbo seal.
Or someone forgot the restrictor on the feed line?
