Re: Honda Power Unit
etusch wrote:
Fri Jun 08, 2018 12:35 pm
I found this after searching that Apple :P
https://historicmotorsportcentral.com/2 ... -head/amp/
gruntguru wrote:
Fri Jun 08, 2018 12:47 am
Thu Jun 07, 2018 2:39 am
gruntguru wrote:
Thu Jun 07, 2018 12:03 am
The ability to create swirl with minimal flow penalty is one advantage. More importantly, the design has more flow potential. The paired valves (eg 2 x inlets), being further separated than a pent-roof design, have less tendency to "shroud" each other. The ideal implementation would have downdraft ports (near the spark plug) which tends to favour flow down the cylinder walls rather than towards the other inlet valve disrupting its flow,
I think there is a scavenging disadvantage. Just visualizing the exhaust escaping to two opposing sides makes my head hurt.
I disagree (unless you are talking about scavenge during overlap). . . and who cares about the efficiency of that flow regime? If you want more scavenge flow just increase the overlap period.
Two valves on one side gives more tumble and there are a few videos out there from big car makers that illustrate how modern "trip" and tumble designs have proven to be optimal for direct injection engines. Though interesting i cant see Honda going to such a clumsy and heavy design just for swirl. It would be easier to have two different sizes of intake valves or staggered opening or something.
I think swirl is more effective than tumble (tumble extinguishes rapidly near BDC compared to swirl). Its just that pent roof heads and chambers don't lend themselves to swirl - the tangential component of flow from a single intake valve is cancelled by the second intake valve. The Apfelbeck chamber is almost conical (even close to TDC) and will support swirl at any piston position.
I don't really have a big opinion on it, just that Nissan and Toyota are sporting tumble in all of their big power direct injection engines.
On the exhaust stroke the initial movement of gas may not swirl despite the exhaust valves being tangential. When the intake valves open soon after there will be swirl but it would break up the previous flow into a new regime and increase mixing of exhaust with fresh air compared to the "straight shot" of a normal layout- almost like internal EGR.
LH44
Don't Toyota or whoever create tumble with port geometry? The "ski ramp" is made easier with wider valve angle but not impossible with a narrower angle.
I'm guessing the ideal for the pre-chamber requires some mixture of swirl and tumble, and the timing of either during the piston stroke is critical. And you can tune a lot of this with your valve opening and closing events.
One of the things that makes engines so interesting is that the time scales for each combustion event are tiny, and so many things have to be properly timed to get the most out of it. From the fuel breaking then forming bonds to the pistons and valve train motion, and flame propagation, all of it needs to be precisely timed to the nanosecond.
roon
roon
445
godlameroso wrote:
Sat Jun 09, 2018 5:50 pm
A nanosecond is a billionth of a second (.000000001). An expansion stroke lasts .01 seconds at 12k RPM. Five degrees before and after TDC would pass in .0018 s.
roon wrote:
Sun Jun 10, 2018 4:47 am
And what about the bond breaking of the hydrocarbons at the spark gap? The species propagation in the pre-chamber? The EGR after she goes bang? How many sparks in that .0018s, injector pulses?
roon
roon
445
godlameroso wrote:
Sun Jun 10, 2018 5:10 am
What about spin direction of their constituent quarks? What about the topological defects which may have formed during a symmetry breaking phase transition in the early universe? If we don't time these events down to the last femtosecond, we'll never break 50% thermal efficiency.
That's the spirit. No seriously the fuel guys are really looking at those time scales. They have the computers and the nerds for it.
Ok this is the last time i move generic Laptime talk and salvage strategies to the General Honda F1 or STR Topic. From now on i will just delete everything off Topic.
Should any off topic chatter happen again, the topic will go into 24h lock down next to deleting the posts.
Nonserviam85
Nonserviam85
godlameroso wrote:
Sun Jun 10, 2018 5:24 am
It is nice for academic purposes but the Law of Diminishing Returns prohibits it for actual applications.
I suppose the fuel chemistry doesn't matter. :roll:
Nonserviam85
Nonserviam85
godlameroso wrote:
Mon Jun 11, 2018 4:57 pm
A lot but not in the nanoseconds realm :)
HPD
352
[media]https://twitter.com/AlbertFabrega/statu ... 2850165761[/media]
Albert Fabrega: FIA considers from Evo1 to Evo2 there are no big changes and they follow rules: If it is similar mass, design, inertia and function does not break park. In other words, there is little difference in ICE, TC, MGUH and MGUK. New FIA approach?
Stef
Stef
But he took a penalty, not sure this rule applies then
Walkman
Walkman
Stef wrote:
Mon Jun 11, 2018 7:46 pm
Because it was his 4th PU ?
