Mercedes AMG F1 W09 EQ Power+
Re: Mercedes AMG F1 W09 EQ Power+
giantfan10 wrote:
05 Jul 2018, 19:24
ScrewCaptain27 wrote:
05 Jul 2018, 18:48
Spoon-shaped RW is back, in a higher downforce configuration compared to Baku:
https://uploads.tapatalk-cdn.com/201807 ... abd333.jpg
Photo by Albert Fabrega
Looks like the exact same wing to me taken from a slightly different height....what makes you think its a different rear wing?
Yeah, me too. Can't see any difference.
ScrewCaptain27
577
Just_a_fan wrote:
06 Jul 2018, 01:04
giantfan10 wrote:
05 Jul 2018, 19:24
05 Jul 2018, 18:48
It’s mentioned on his Twitter page, could be he noticed a slight difference since he is there
- Serj Tankian
Yes, or he is looking for clicks...
I remember taking photos of a car at Silverstone in, ooh, 2001. Took them to a friend who was working for a different team. "yeah, we saw that last race".
Online photos are a piss poor metric.
roon
roon
412
The one marked 'Silverstone' seems to have a flatter middle section. Use the T-wing as a visual reference. You'll see that the one marked 'Baku' has constant curvature, with no section parallel to the T-wing.
Not to throw dirt on the previous posters, but here's a shovel analogy:
Silverstone is a square nose. Baku was a round nose.
zibby43
zibby43
613
roon wrote:
06 Jul 2018, 03:38
https://www.fs.fed.us/eng/pubs/htmlpubs ... ovtype.jpg
Absolutely.
The central section on the lower mainplane on the Silverstone-spec has a flatter leading edge, as both Steven and you noted..
zibby43
zibby43
613
JasonF1
Wonder what's that for. Looks super draggy.
atanatizante
109
The main purpose of these bargeboards is for managing airflow when the car is on a straight line or when it`s on a yaw? From my side, it looks they are quite draggy from the lateral point of view ...
Jesus
bonjon1979
bonjon1979
30
I wonder if they want to use a particularly fancy camera but to do so they need to make it be part of a mirror assembly?
zibby43
zibby43
613
MtthsMlw wrote:
06 Jul 2018, 10:45
Draaaaaaag
It’s just to evaluate tire temperatures in practice.
atanatizante
109
Is it me or they just moved a little bit backwards that T wing?
Jesus
atanatizante
109
A new bump on the lower front wishbone :
Jesus
Sierra117
atanatizante wrote:
06 Jul 2018, 13:53
https://postimages.org/
It's in exactly the same spot from what I can see. The two pictures are at a slightly different angle. You can compare the placement of things with other reference points; e.g. the T-wing intersects the "77" in the same spot in both pictures (in the middle of the horizontal line that makes up a "7").
NIKI LAUDANZ SolidarityCubolligraphy | Instagram | Facebook
#Aerogorn & #Flowramir
astracrazy
astracrazy
31
atanatizante wrote:
06 Jul 2018, 13:53
They are the same. T-wing and rear wing. Its just slightly different angle and lighting
