2018 McLaren F1 Team - Renault
Re: 2018 McLaren F1 Team - Renault
Andrew Benson:
Mercedes announce significant technical changes. Engineering director Aldo Costa and performance director Mark Ellis will leave their roles at end of season. Chief designer John Owen to replace Costa as head of engineering. Chief Vehicle Dynamicist Loic Serra to replace Ellis
Is Costa an option for Mclaren as Team Principal ??
mclaren111 wrote:
12 Jul 2018, 15:50
Andrew Benson:
Nope.
https://twitter.com/tgruener/status/1017402522909138945
M840TR
M840TR
315
mclaren111 wrote:
12 Jul 2018, 15:50
Andrew Benson:
He's a powertrain guy. No business being team principle.
bonjon1979
bonjon1979
30
M840TR wrote:
12 Jul 2018, 16:12
mclaren111 wrote:
12 Jul 2018, 15:50
Andrew Benson:
He was technical director at Ferrari, and their chief designer before then so slightly more than a powertrain guy.
M840TR
M840TR
315
bonjon1979 wrote:
12 Jul 2018, 16:40
M840TR wrote:
12 Jul 2018, 16:12
mclaren111 wrote:
12 Jul 2018, 15:50
Andrew Benson:
He's a mechanical engineer by profession and yes he was TD and has served in similar capacity in few other teams but he's mainly been involved in design/engineering roles which is worlds apart from being a team principle. I wouldn't mind if he filled in Tim Goss' seat though.
PhillipM wrote:
12 Jul 2018, 13:42
Nobody ruled it out, having one problem doesn't stop you from having another.
The assumption is they compromised the rear mechnically for aero gains on other tracks deliberately, and without the aero working properly it's giving them a bit of a double whammy of issues at traction biased circuits.
I was looking at Ferrari's rear end, it looks almost the same setup....that doesn't mean there isn't a problem...but I think it makes it a less obvious problem.
Jolle
Jolle
133
diffuser wrote:
12 Jul 2018, 21:07
PhillipM wrote:
12 Jul 2018, 13:42
Not quite. Although the pull rod is attached inwards more at Ferrari then the Merc for instance, it looks the upright is made wider at the top. That way, at the Ferrari, you still have 100% of wheel movement. At McLaren its probally somewhere between 60-70%. Plus, the push rod on the Mclaren almost points forward. In theory it should be all ridged and should have no losses or flex, but.... it’s just too ambitious (same kind of problem the F14T had with it’s front suspension)
McG
-19
It might not be any specific problem. Maybe other teams have just done a better job or in Haas case have been very smart with a close partnership with Ferrari. Remember the Ferrari engine is just as good as Merc now so that's a massive boost for Ferrari powered teams, then you've got Force India who have some sort of relationship going on with Merc. Renault I think are ahead of McLaren because it's their own engine. STR and Williams are just dire, at least McLaren aren't in that situation (anymore).
I think McLaren could just be in their natural place at the moment and their main issue is fully getting used to the Renault engine and what that may involve.
I'm sure they can and want to update and change certain parts of the car just like every other team.
Finally, everyone knows that Red Bull is a joke and Max Verstappen is overrated.
NL_Fer
NL_Fer
82
PhillipM wrote:
12 Jul 2018, 13:42
Correct, who knows, maybe their suspension doesn’t stiffen up enough under high speed (cornering). That could be called an aero problem right?
M840TR
M840TR
315
NL_Fer wrote:
13 Jul 2018, 08:23
PhillipM wrote:
12 Jul 2018, 13:42
It's the low speed corners where it struggles more.
Autosport.com
McLaren Formula 1 boss Zak Brown says the decision-making process at the team had become "gridlocked", with too much reliance on committees.
"The structure is not allowing certain individuals to be as entrepreneurial as I would like them to be," said Brown.
"I think it has not enabled them to make decisions quickly enough.
"My job leading the Formula 1 team is to ultimately put that pace into the organisation, give the direction,
get the right leadership in place
and get on with getting back to where I think everyone recognises McLaren should be."
Definitely positive steps in the right direction. I wish him well and hope 2019 will bring a good step forward.
NL_Fer
NL_Fer
82
M840TR wrote:
13 Jul 2018, 08:38
NL_Fer wrote:
13 Jul 2018, 08:23
PhillipM wrote:
12 Jul 2018, 13:42
Teams run a pseudo-active suspension. A passive system, which acts like an active one, without the use of a computer and electronic actuators.
For optimal performance, they need a soft suspension for good mechanical grip during low speed corner exits, but a very firm/stable setup for high speed cornering, because to much roll will hurt aerodynamics.
If McL’s psuedo-active suspension is less advanced, they will be to stiff for low speed corners or to soft on hi speed corners.
M840TR
M840TR
315
NL_Fer wrote:
13 Jul 2018, 12:48
M840TR wrote:
13 Jul 2018, 08:38
NL_Fer wrote:
13 Jul 2018, 08:23
Which suspension? Are you talking about the one introduced in Spa and banned this year?
McLaren said their aero problem was causing them to be slow out of the corners and top speed.
Let's see where they are after they fix that before going off in 100 directions.
I for one am Leary of their change of direction stability. Think I saw a weakness there in those graphs I had posted way back. But there is no point talking about that issue, it might change after they fix the aero issue.
M840TR
M840TR
315
"I think it has not enabled them to make decisions quickly enough. I think sometimes there is an appropriate time for decision by committee, and then I think there's also times when there should be decisions by individuals.
What kind of system are they running in there? Does everything that go onto the car or happen at the factory has to be approved by a committee of some kind? No wonder Zak says they need to be more "nimble".
